March 12, 2013, 04:59 |
Udf viscous resistance compiling error
#1 | |
Rep Power: 13 |
i have a problem with a Udf for a porous media. I have to define a time-dependant viscous resistance for a 3d volume, but when i'm going to compile the udf, fluent reports this error: Error: The UDF library you are trying to load (libudf) is not compiled for 3d on the curent platform (win64). The code is: Quote:
Thx |
March 12, 2013, 06:44 |
Stuart Buckingham
Rep Power: 25 |
Surely there must have been a compile error before it loaded?
Did you compile it from within Fluent? |
March 12, 2013, 08:54 |
#3 | ||
Rep Power: 13 |
It builds the udf, fluent displays this messages after build:
i tried to interpret the udf and it works so it must be a problem of the compiler, but i don't understand what it's wrong because i can compiler other udfs. |
March 12, 2013, 11:22 |
Bill Wangard
You probably compiled the UDF against a different version than you are actually running. For example, you may have compiled 3d double precision, but started 3d single precision, or 3d serial, and you started 3d parallel.
March 13, 2013, 07:20 |
Rep Power: 13 |
But i compile the udf within the case, so it should be compiled in the same version of the case, or not?
March 13, 2013, 12:05 |
Bill Wangard
Yes. You are doing it the correct way.
I am beginning to think that you are not using the 64-bit compiler. Have you ever been able to successfully able to compile any UDF, or is this the only time you've had the problem? |
March 14, 2013, 13:00 |
Rep Power: 13 |
It's the first time that i have this problem, I have compiled successfully other udf
compiling, error, udf, viscous resistance |
polynomial thermophysical properties II | sebastian | OpenFOAM Running, Solving & CFD | 54 | November 21, 2019 07:12 |
Pressure outlet boundary condition | rolando | OpenFOAM Running, Solving & CFD | 62 | September 18, 2017 06:45 |
[OpenFOAM] Native ParaView Reader Bugs | tj22 | ParaView | 270 | January 4, 2016 11:39 |
Compiling dynamicTopoFvMesh for OpenFOAM 2.1.x | Saxwax | OpenFOAM Installation | 25 | November 29, 2013 05:34 |
POSDAT problem | piotka | STAR-CD | 4 | June 12, 2009 08:43 |
