Problem in UDF compilation
Like Tree1Likes
  • 1 Post By Galileo
Old   May 31, 2012, 13:24
Default Problem in UDF compilation
Bimlesh
iitgbim is on a distinguished road
here is part of udf, where I am getting error (not defined variable)
# include "udf.h"
# define C 0.3
# define diam2 2.e-4
# define Cmu 0.09
DEFINE_EXCHANGE_PROPERTY(modified_drag,cell,mix_th read,s_col,f_col)
Thread*thread_l;
Thread*thread_g;
real slip_x;
real slip_y;
real slip_z;
real slip;
real k_l;
real d_l;
real mu_t_l;
real mu_l;
real rho_l;
real rho_g;
real reyp;
real cd;
/* liquid phase-primary*/
thread_l=THREAD_SUB_THREAD(mix_thread,s_col);
/* gas phase-secondary*/
thread_g=THREAD_SUB_THREAD(mix_thread,f_col);
/* slip velocity*/
slip_x=C_U(cell,thread_l)-C_U(cell,thread_g);
slip_y=C_V(cell,thread_l)-C_U(cell,thread_g);
slip_z=C_W(cell,thread_l)-C_W(cell,thread_g);
/*Parameters*/
rho_g = C_R(cell, thread_g);
rho_l = C_R(cell, thread_l);
mu_l = C_MU_L(cell, thread_l);
/*turbulent kinetic energy and dissipation rate for liquid*/
k_l=C_K_L(cell,thread_l);
d_l=C_D_L(cell,thread_l);
It says C_D_L is not defined
iitgbim is offline   Reply With Quote
Old   May 31, 2012, 14:45
Fer Villa
fevi84 is on a distinguished road
In Fluent,
the turbulent kinetic energy is:C_K(c,t)
the turbulent kinetic energy dissipation rate is: C_D(c,t)
C_K_L(c,t) is laminar thermal conductivity
C_D_L(c,t) I don't know. you are sure that variable macro there
fevi84 is offline   Reply With Quote
Old   June 1, 2012, 00:34
Bimlesh
I have intended to model a new drag law for two-phase flow (gas -liquid).
Here L denotes the liquid phase. Here is the full UDF. Please go through and suggest me why it is saying d_l=C_D_L(cell,thread_l); C_D_L is undeclared variable.
Old   June 1, 2012, 09:59
Engr Adeniyi
Galileo is on a distinguished road
You are modelling a two phase flow. Fluent does not know if one phase is liquid or not, it only knows it as "one phase" and the "other phase". You are the one referring to one of the phases as liquid. Fluent knows the cell content with the thread.
Therefore, appending _L to the variable does not mean the variable will refer to the liquid phase. You should call the correct thread.
If you could have written it as C_D_S to mean solid and C_D_V to mean vapour and your code will not run (or run correctly). If you add _G to mean Gas you will be wrong because most of the _G in the variables refer to gradient.
To answer your question, I will suggest you do the following.
(1) Turn on the correct Turbulence model (k-eps) I guess.
(2) Change your code lines to:
k_l=C_K(cell,thread_l);
d_l=C_D(cell,thread_l);
You have to be sure these refer to the correct threads respectively:
If your code works please reply in this thread it may help someone else.
DungPham likes this.
Galileo is offline   Reply With Quote
Old   June 1, 2012, 10:23
Bimlesh
Thanks
It is working.
Old   June 1, 2012, 10:52
Tamphasana
thiyam is on a distinguished road
thanks for you reply Galileo, the same udf code has successfully interpreted but the problem is while doing iteration it shows error like
FLUENT received fatal signal (ACCESS_VIOLATION)
This problem has solved now but again after exactly 11th iteration error shows as
Error: divergence detected in AMG solver:k
Error Object)
I need your help
thiyam is offline   Reply With Quote
Old   June 1, 2012, 11:18
Bimlesh
The udf is working fine but when i go for iteration, it shows error like Error: FLUENT received fatal signal (ACCESS_VIOLATION) 1. Note exact events leading to error. 2. Save case/data under new name. 3. Exit program and restart to continue. 4. Report error to your distributor. Error Object: ()
Please suggest me
Old   June 4, 2012, 01:30
Bimlesh
While compiling I am getting Warning C4700: Local variable mu_l used without having been initialized.
I am also getting no changes in gas phase wile iterating. Please suggests me.
Old   June 5, 2012, 01:44
amindavari is on a distinguished road
could anyone help me: i provided an udf that set a profile on the boundary, at first i couldnt even interprete this udf, however by adding two lines in code i finally could interprete it. now i encounter a new problem, when i start iterating, an error entitled "Floating point error: invalid number" appears. what should i do?
thank you in advance
#include "udf.h"
DEFINE_PROFILE(heatflux, thread, position){
#if !RP_HOST
real y[ND_ND]; /* this will hold the position vector */
real z;
face_t f;
begin_f_loop(f, thread)
F_CENTROID(y,f,thread);
z = y[2];
F_PROFILE(f, thread, position) = 283889.07*cos((4.0*atan(1.0)/0.815)*(z+0.01005));
end_f_loop(f, thread)
#endif
amindavari is offline   Reply With Quote
Old   June 7, 2012, 09:56
Engr Adeniyi
Sorry for the late response.
1.)
That warning is telling you that you have declared a variable but you did not initialise it before using it.
That can be ignored or you put an initial value like in this example:
real mu_l=0.;
or
/* DECLARATIONS of variables */
real a;
real b;
real mu_l;
/* Initialising varibles */
a=b=mu_l=0.;
2.)
I don't really know what you are trying to achieve, but generally when you write a code like that, you need to HOOK the UDF to the interface. So please check UDF manual for how to hook your particular UDF to FLUENT. You may want to check this: FLUENT MANUAL
Old   June 7, 2012, 10:11
Engr Adeniyi
#include "udf.h"
#if !RP_HOST
real z;
face_t f;
z = y[2];
#endif
You need to check if it is a machine issue (eg are you using double or single precision solver?). Try and change the solver.
You can also check through to understand what is going on at the stage of iteration and debug, just like you will debug any "normal" code.
int Stopper;
Stopper=0;
#if !RP_HOST
real z;
real ATAN,COS,Profile;
face_t f;
z = y[2];
ATAN=atan(1.0);
COS= cos((4.0*ATAN/0.815);
Profile=283889.07*COS*(z+0.01005));
if (Stopper<20)
{Stopper++; /*Print only twenty times DONT HANG MY COMPUTER INSIDE A LOOP */
CX_Message(" Z= %g Atan=%g Cos=%g Profile Val=%g",z,ATAN,COS,Profile);
F_PROFILE(f, thread, position) =Profile;
#endif
Hope it works/helps?
Old   June 7, 2012, 10:22
Engr Adeniyi
Error Object)
I need your help
That error might be that you are attempting to access a variable from a model you are not using. Eg If you are accessing turbulence variables from UDF while your model setup is laminar, you will face such issue. If also, you are solving a model with k-epsilon and you are trying to access FLUENT data from k-omega, you will also face such.
Try and look through the variables and be sure you have switched on the correct variable.
If you face divergence problem, it is possible you have the wrong discritisation scheme and your solution is not converging. It is also possible you are getting a division by zero or too big number. So debug your code by printing the values you are changing. You can print using: (Formatting using C-formating). But becareful when printing inside a big loop. You can use a stopping criteria to stop print, eg using a counter variable.
CX_Message("*****VARIABLES C_Mu =%E, C_K=%E", c_mu,c_k);
Old   June 9, 2012, 03:21
Originally Posted by Galileo View Post
int Stopper;
Stopper=0;
#if !RP_HOST
real z;
face_t f;
z = y[2];
ATAN=atan(1.0);
if (Stopper<20)
#endif
Thank you for the response.
it should be mentioned that this code works properly by one processor. however, when i use parallel mode in fluent, i encounter this error after iteration. can i interprete udf in parallel mode or should compile?
Old   September 19, 2014, 01:56
Default if u want to know email me
  #14
sarighulikhan
hane is on a distinguished road
becouse u restrict host from getting access to real r
hamed.moradkhani@yahoo.com
hane is offline   Reply With Quote
Old   September 19, 2014, 06:20
Default udf for superheated steam
  #15
viral nagar
viralnagar5692 is on a distinguished road
can anyone give me the udf file for superheated steam properties?
viralnagar5692 is offline   Reply With Quote
ATTN ALL: SOLUTON TO UDF COMPILE PROBLEM Rizwan Fluent UDF and Scheme Programming 40 March 18, 2018 06:05
UDF problem mansha goraya FLUENT 0 October 29, 2007 00:31
udf compiling problem akr FLUENT 3 August 22, 2007 07:14
UDF PROBLEM anant FLUENT 2 January 17, 2007 00:15
parallel UDF problem kerem FLUENT 2 June 20, 2006 06:56
