User-defined function for Drag modification in multiphase flow
Old   October 30, 2017, 22:54
Default User-defined function for Drag modification in multiphase flow
Rakhim
Rakhim is on a distinguished road
Hello everyone,
I am in the process of setup of a multiphase flow and I need to develop user-defined function for drag coefficient. In the 'Phase Interaction' tab I chose 'Drag' and gidaspow model. And now, for drag factor, I want to choose user-defined and write a script with my own function which will calculate drag coefficient. How can I do that? I am just starting with Fluent. If you advise me some preliminary steps, so I can follow them up, I will appreciate it very much.
Thanks!
Rakhim is offline   Reply With Quote
Old   November 3, 2017, 10:49
Micael
Micael is on a distinguished road
There is an example UDF for that in the UDF user guide.
Micael is offline   Reply With Quote
Old   November 17, 2017, 07:31
Rakhim
Dear Micael,
I built and loaded udf ('custom_drag' from fluent manual) successfully and without errors. But it was not appeared in dialog box (Warning message says 'No user-defined functions have been loaded'). Are you aware of this problem?
Old   November 30, 2017, 07:37
pakk will become famous soon enough
Originally Posted by Rakhim View Post
Dear Micael,
It means that you did not build and load the udf successfully and without errors. Even though you think so.
You probably missed the errors that come onto your screen when you click 'build'. These errors are not red, you have to look for them in the 'normal' black text in the text user interface.
pakk is offline   Reply With Quote
drag modification, fluent, gidaspow, user defined function
[blockMesh] BlockMesh FOAM warning gaottino OpenFOAM Meshing & Mesh Conversion 7 July 19, 2010 14:11
Problem with compile the setParabolicInlet ivanyao OpenFOAM Running, Solving & CFD 6 September 5, 2008 20:50
Droplet Evaporation Christian Main CFD Forum 2 February 27, 2007 06:27
User defined function of mass flow rate Eric FLUENT 1 April 22, 2005 18:15
User Defined Function for convection coefficient ereiss FLUENT 1 July 8, 2004 16:10
