souce term-error in both "interpreting and compiling"
Old   June 10, 2013, 07:39
Default souce term-error in both "interpreting and compiling"
Moha
ahvz is on a distinguished road
when I interpreting the code I receiving :
two "parse error" for the highlighted lines . what is wrong in the code?
#include "udf.h"
DEFINE_SOURCE(energy_udf,c,t,dS,eqn)
real source;
if(N_TIME > 0)
if (C_T(c,t) > C_T_M1(c,t))
if (C_T_(c,t)<=297. && C_T(c,t)>=287.)
source =(-0.0235*pow(temp,3.))+(20.246*pow(temp,2.))-(5816.7*pow(temp,1.))+557045;
dS[eqn] =(-0.0705*pow(temp,2.))+(40.492*pow(temp,1.))-5816.7 ;
else if (C_T(c,t) < C_T_M1(c,t))
if (C_T_M1(c,t) <= 285.0 && C_T(c,t) >= 297.0)
source =(-0.0227*pow(temp,3.))+(19.483*pow(temp,2.))-(5568.7*pow(temp,1.))+530603;
dS[eqn] =(-0.0681*pow(temp,2.))-(38.966*pow(temp,1.))-5568.7;
return source;
when I compiling the code I reciving the below errors
..\..\src\test.c(36) : warning C4003: not enough actual parameters for macro 'C_T_'
..\..\src\test.c(36) : error C2059: syntax error : ')'
..\..\src\test.c(51) : error C2059: syntax error : 'return'
..\..\src\test.c(52) : error C2059: syntax error : '}'
any helps ?
ahvz is offline   Reply With Quote
