Declation of a vector in a UDF
Old   June 16, 2013, 04:02
Default Declation of a vector in a UDF
Amelia2 is on a distinguished road
I am having some troubles with the declaration of a vector in a UDF. The UDF is used for varying the time step. The vector is using for describing this variation.
In this exemple, I want a first time step of 1, then of 5, then of 2 and finally of 4 for having successively a flow time of 1, 6, 8, 12.
So, I declare the vector by this way :
V[3]=(1, 5, 2, 4);
And then I use a for loop by this way where dt is the time step:
for(i=0; i<=3; i++)
{dt=V[i];}
The problem is that I didn't have the except result. I have successively a flow time of 4, 8, 12, 16.
I think that only the last coordinate of the vector is taken into account. The resulting flow time is the last coordinate, two time the last coordinate, ect.
So, I suppose that I incorrectly declare the vector. In the bracket, I define the vector dimension and in the parenthesis I define the coordinates of the vector.
Can someone explain me how to declare a vector for my purpose ?
Thanks in advance.
Amelia2 is offline   Reply With Quote
Dynamic Mesh UDF Qureshi FLUENT 7 March 23, 2017 07:37
UDF parallel error: chip-exec: function not found????? shankara.2 Fluent UDF and Scheme Programming 1 January 16, 2012 22:14
How to add a UDF to a compiled UDF library kim FLUENT 3 October 26, 2011 21:38
UDF...UDF...UDF...UDF Luc SEMINEL FLUENT 0 November 25, 2002 04:03
UDF, UDF, UDF, UDF Luc SEMINEL Main CFD Forum 0 November 25, 2002 04:01
