can not include Windows.h and sys/stat.h headers
Hi all,
I have made a UDF and I am having numerous errors when I try and use the following headers #include <Windows.h> #include <sys/stat.h> for the windows header fluent gives me huge amount of redifinition errors or says unexpected '$' in macro definition etc. for the <sys/stat.h> header I keep getting linker errors for undefined struct stat. following code is where I use stat to check of a file exists. int FileExists(const char* filename){ struct __stat64 buf; stat(filename, &buf); /* stat(filename, &buf) returns 0 for completion and -1 for fail */ if ( stat(filename, &buf) == -1) { /* returns false if file does not exist */ return 0; } /* returns true if a file already exists */ return 1; } i have tried using struct_stat64 and struct stat but this is still not working. this piece of code compiles fine on Xcode ( just for testing) and VS2010. I am using VS2010 Express and installed SDK 7.1. Installed SDK 7.1 first due to failed installation occuring if I tired to install it after VS2010 Express. also needed the Windows.h file for the Sleep( time in milliseconds ) command . If I file does not exists I needed it to pause for very short time before checking again, did not want the program speeding away and crashing. EDIT: actual error for the stat problem Additional_functions.obj : error LNK2019: unresolved external symbol stat referenced in function FileExists libudf.dll : fatal error LNK1120: 1 unresolved externals |
Did you solve this problem at last? I have the same problem as you did. Could you please help me out?
Have you figured out how to include <Windows.h> in your code? Anyone has an idea how to include <Windows.h> in FLUENT UDF? Kind regards, Alex |
The compiler does not know where to find windows.h. So maybe you can replace
#include <Windows.h> Code:
#include "c:\correct_folder\Windows.h" (I am not trying to insult anybody for being a bad programmer: I think I am myself also not good enough to make specialized complex applications that really need windows.h.) |
