UDF Help
Old   July 26, 2013, 05:41
Default UDF Help
Jessica
Jess is on a distinguished road
Hey all,
Im currently writing a UDF.
I calculate the force in an UDF called DEFINE_CG_MOTION
The question is how do i use this force to trigger the inflow in another UDF called DEFINE_PROFILE
I would use
If Force > number
DEFINE_PROFILE = 5
Else DEFINE_PROFILE = 0
but im not sure how to recall the force, as i get the error message, Force is not defined
Thanks
Jess is offline   Reply With Quote
Old   July 28, 2013, 08:29
Christopher Hershey
Hershey is on a distinguished road
You could do this a variety of ways I imagine.
First of all though, does your DEFINE_CG_MOTION only provide a single value for the entire domain every time it runs? I never used this macro before, but anyway, you should look into both F_UDMI or C_UDMI.
For a DEFINE_PROFILE, the macro is passed the thread so you would loop through either the faces or the cells for the F_UDMI and C_UDMI respectively.
Are you familiar with how User-Defined Memory works? I can continue on if this seems like the path you want to go down.
I also use Scheme variables, but you may find it easier just to stick with the UDM.
Please post back if you have questions or would like further explanation.
Hershey is offline   Reply With Quote
Old   July 28, 2013, 15:41
Jessica
my cg_motion sums up all the forces around the faces of a object everytime it runs.
This is what i understand of the macros u mentioned.
i can use F_UMI in my DEFINE_CG_MOTION to store the forces calculated and use Execute_on_demand? to use it in Define_PROFILE? or do i use the same macro F_UMI to retrieve the data?
I will give this a try tomorrow morning.
Jess
Old   July 28, 2013, 19:06
Christopher Hershey
The F_UDMI will store the value calculated from your UDF into each respective face on the thread. For instance an example from the manual:
/* Compute face temperature and store in user-defined memory */
begin_f_loop(f,t)
temp = F_T(f,t);
F_UDMI(f,t,0) = (temp - tmin) / (tmax-tmin);
end_f_loop(f,t)
You can see that the temperature is being retrieved by F_T(f,t) and after some manipulation it is stored in the respective face/thread combination of the face loop. If for instance F_UDMI(f,t,0) was equal to a constant, then the constant would be saved over every face/thread combination.
Once you save the value of your forces in F_UDMI, you can then access it from any UDF, even the DEFINE_PROFILE.
You shouldn't need an Execute_on_Demand macro.
Old   July 30, 2013, 06:54
Jessica
Yes method works
Thank you, now im just working on my inlet vel udf
Dynamic Mesh UDF Qureshi FLUENT 7 March 23, 2017 07:37
Source Term UDF VS Porous Media Model pchoopanya Fluent UDF and Scheme Programming 1 August 28, 2013 06:12
UDF parallel error: chip-exec: function not found????? shankara.2 Fluent UDF and Scheme Programming 1 January 16, 2012 22:14
UDF...UDF...UDF...UDF Luc SEMINEL FLUENT 0 November 25, 2002 04:03
UDF, UDF, UDF, UDF Luc SEMINEL Main CFD Forum 0 November 25, 2002 04:01
