January 16, 2012, 02:53 |
Need UDF for Mixture Model
Vaibhav Rai Khare
Rep Power: 14 |
I am working on heat and mass transfer of mixture model.and need to know how the UDF file will be made???
can any 1 provide its sample of any tutorial file??? |
January 17, 2012, 09:22 |
hi
shoeb khan
Rep Power: 14 |
For heat transfer i think that there is no need of any udf as such .
You just define the temperature at some wall it has to work. You need a udf for masss transfer which you can find in ansys udf manual that is available on net.You just copy paste that and just change the mass transfer equation to the equation that is needed for your work. Thanks shk |
January 17, 2012, 10:29 |
Real Name :)
Rep Power: 16 |
I would not specify the temperature directly, as suggested by shk12345; this is asking for simulation instabilities. I would allow fluent to calculate it for you. See example 2 for how to define heat transfer between phases: http://my.fit.edu/itresources/manual...udf/node61.htm
See the example here for mass transfer: http://my.fit.edu/itresources/manual...udf/node63.htm ComputerGuy |
January 17, 2012, 10:34 |
shoeb khan
Rep Power: 14 |
The first link that you shared is drag law used by multiphase models as eulerian model and mixture model . That is not for temperature specifications.
For mass transfer as i said to you you can copy that udf and change it with your mass transfer equation in the MT equation used in that udf. regards shk |
January 17, 2012, 10:36 |
Real Name :)
Rep Power: 16 |
OK -- if the mixture model is used (was thinking Eulerian), all phases have the same temperature. I stand corrected! Temperature must be specified; be careful.
FYI: If you choose to use the Eulerian model, the heat transfer law is on the page provided as follows: Code:
#include "udf.h" #define PR_NUMBER(cp,mu,k) ((cp)*(mu)/(k)) #define IP_HEAT_COEFF(vof,k,nu,d) ((vof)*6.*(k)*(Nu)/(d)/(d)) static real heat_ranz_marshall(cell_t c, Thread *ti, Thread *tj) { real h; real d = C_PHASE_DIAMETER(c,tj); real k = C_K_L(c,ti); real NV_VEC(v), vel, Re, Pr, Nu; NV_DD(v,=,C_U(c,tj),C_V(c,tj),C_W(c,tj),-,C_U(c,ti),C_V(c,ti),C_W(c,ti)); vel = NV_MAG(v); Re = RE_NUMBER(C_R(c,ti),vel,d,C_MU_L(c,ti)); Pr = PR_NUMBER (C_CP(c,ti),C_MU_L(c,ti),k); Nu = 2. + 0.6*sqrt(Re)*pow(Pr,1./3.); h = IP_HEAT_COEFF(C_VOF(c,tj),k,Nu,d); return h; } DEFINE_EXCHANGE_PROPERTY(heat_udf, c, t, i, j) { Thread *ti = THREAD_SUB_THREAD(t,i); Thread *tj = THREAD_SUB_THREAD(t,j); real val; val = heat_ranz_marshall(c,ti, tj); return val; } |
January 17, 2012, 10:50 |
shoeb khan
Rep Power: 14 |
Thanks for that udf
that is ranz marshal law in eulerian model in fluent. ""The default heat transfer option between the continuous phase and the particles is Ranz Marshall. The Ranz Marshall correlation is also applicable to Eulerian multiphase flow."" /quote/ http://www.kxcad.net/ansys/ANSYS_CFX...h07s05s03.html it is not for temperature but for h eat transfer between the phase and you need not to put it as udf in fluent it is already build in fluent. thanks and regards shk |
March 2, 2013, 22:28 |
#7 | |
cfd^2
Rep Power: 13 |
Is this piece of code the one that is implemented in FLUENT to calculate the heat transfer coefficient by Ranz-Marshall model? If yes, it is really interesting, since I'll be able to change a few things and redefine it as a User Defined parameter in the interaction panel for heat transfer in multiphase simulation... Best Regards, cfd^2 |
September 5, 2013, 00:03 |
#8 | |
C
Display Modes | |
Writing UDF for Eulerian model | golriz | Fluent UDF and Scheme Programming | 7 | November 3, 2011 06:30 |
UDF for Heat Exchanger model | francois louw | FLUENT | 2 | July 16, 2010 03:21 |
Modifying Pressure swirl atomizer model by UDF | jeff_F | FLUENT | 0 | May 22, 2010 10:22 |
UDF: how to know domain number in the model? | mssound | FLUENT | 0 | May 17, 2010 16:00 |
The problem of UDF in Non premixed combustion model | zhangyuan | Main CFD Forum | 0 | May 25, 2009 10:41 |
