Urgent help needed in creating UDF's
Old   October 11, 2013, 23:48
Post Urgent help needed in creating UDF's
Sharath Chandra. J
sharath chandra is on a distinguished road
I am currently working on validation of a small project and it includes flow conditions in parabolic profile and temperature conditions varying in a linear fashion increasing along the Y axis.
Velocity varies as
u(y)=12(y-(y^2)) and y ranges from -1/6 to 1/2
Temperature varies as
θ(y)=(1-2y) and again y ranges from-1/6 to 1/2
My main problem is i don't understand how to define the centre-line velocity i.e maximum velocity and temperature conditions. Also from a previous experience, I couldn't include two different UDF's for different boudary conditions. Is it possible to write both the UDF's in a single program
I have included all the required data probably. In case anything else is required, I would respond. Please help me out.
sharath chandra is offline   Reply With Quote
Old   October 12, 2013, 09:55
ghost82's Avatar
Rick
ghost82 will become famous soon enough
Velocity varies as
Hi!
Please define your equations; if I plot the velocity equation between -1/6 and 1/2 I have negative velocities and the profile of the parabola is not complete.
If I translate the parabola and if I plot that translated parabola the profile of the parabola is not complete.
Do the same with the T equation.
Can you define better your problem?
Daniele
ghost82 is offline   Reply With Quote
Old   October 12, 2013, 13:12
Post RE: Data clarification
Sharath Chandra. J
Originally Posted by ghost82 View Post
Hi!
Daniele
Hi! First let me thank you for such an immediate response. I am really grateful to you for your help. Anyways back to the problem at hand.
The problem I am working on is a backward facing step flow with varying expansion ratios. I have to validate the flow conditions in the problem for varying ratios of S/H as shown form the figure. From the paper I've been trying to validate this sentence is verbatim.
" The physical domain in the X-direction is bounded by 0 < x < (30H) and in the y direction it is bounded by –S/DH < y < 1/2.
The flow at the inlet, x=0 is assumed to be hydro-dynamically fully developed, where a dimensionless parabolic velocity distribution is given as
u(y)=12(y-y^2)."
If having the Reynolds number of the flow would be helpful, then it is 800 and the fluid is assumed as water with standard properties.
temperature bc, udf, velocity bc
urgent help needed (rhie-chow interpolation problem) Ardalan Main CFD Forum 2 March 18, 2011 15:22
Parse error in UDF, URGENT HELP NEEDED!!! Boris Kloser FLUENT 2 December 12, 2009 03:16
help needed in Turbulent flow (URGENT) mike FLUENT 7 November 7, 2008 06:11
Urgent help needed with spray injection nick Siemens 14 June 29, 2008 18:48
Urgent Help Needed! Ken Adams FLUENT 3 September 25, 2007 23:50
