October 18, 2013, 05:53 |
UDF macro not compliled
Marie
Rep Power: 12 |
Hi everybody,
When I compiling UDFs, I can build "libudf", but I can't load it. So could anyone can help me or to explain why? Opening library "c:\users\gxu2\desktop\vof\libudf"... Error: The UDF library you are trying to load (libudf) is not compiled for 2d on the curent platform (ntx86). I have put the file "vitesse.c" in the libudf file. And here is my UDF macro : /************************************************** ********************* vprofile.c UDF for specifying steady-state velocity profile boundary condition ************************************************** **********************/ #include "udf.h" DEFINE_PROFILE(x_velocity, thread, position) { real x[ND_ND]; /* this will hold the position vector */ real y; face_t f; begin_f_loop(f, thread) { F_CENTROID(x,f,thread); y = x[1]; F_PROFILE(f, thread, position) = 5; } end_f_loop(f, thread) } Thank you very much! |
October 22, 2013, 06:20 |
tran trung
Rep Power: 12 |
do you meet error in the fluent ?
October 22, 2013, 06:24 |
Marie
Rep Power: 12 |
Yes actually, I have tried with just "interpreting " and as select my UDF for the moving wall I got the error
"ERROR : incorrect grid motiom UDF x-velocity on zone 7" and I donīt know what it means |
October 22, 2013, 07:00 |
tran trung
Rep Power: 12 |
can I see your udf ?
October 22, 2013, 07:14 |
Marie
Rep Power: 12 |
For the moment I just want to try to have a constant velocity on the moving wall. I want to test af first my model. So here is my UDF
/************************************************** ********************* vprofile.c UDF for specifying steady-state velocity profile boundary condition ************************************************** **********************/ #include "udf.h" DEFINE_PROFILE(x_velocity, thread, position) { real x[ND_ND]; /* this will hold the position vector */ real y; face_t f; begin_f_loop(f, thread) { F_CENTROID(x,f,thread); y = x[1]; F_PROFILE(f, thread, position) = 5; } end_f_loop(f, thread) } |
October 22, 2013, 07:32 |
tran trung
Rep Power: 12 |
your udf report velocity but i don't see to report it. your udf report presssure. Do you use complied or interpret ?
October 22, 2013, 07:34 |
Marie
Rep Power: 12 |
I interpret my UDF.
October 22, 2013, 07:51 |
tran trung
Rep Power: 12 |
I have check your udf. it is correct. after you interpret , you go to boundary condition to report udf.
October 22, 2013, 08:06 |
#9 |
Marie
Rep Power: 12 |
Thank you for your answer. and thank you for checking my UDF.
After I interpret, I go to boundary condition. Then I select my moving wall. Should I select moving wall in Momentum ? after if I want to report the udf it is not possible. I can go to profile and then I can t even read my UDF profile. I can only load and find my UDF in the dynamic mesh (dynamic Mesh zone) but after I have got a fatal error. |
October 22, 2013, 08:47 |
#10 |
tran trung
Rep Power: 12 |
if you report wall moving, you can't do as a such. to report wall moving, you have to use dynamic mesh and use complied.
- download SDK command prompt - start fluent by sdk. - then complied udf |
October 22, 2013, 09:05 |
#11 |
Marie
Rep Power: 12 |
I actually have no admin right to try that immediatly and download Visual Studio, but thank you very much for your answer. I would let you know if it is working.
October 23, 2013, 04:09 |
#12 |
tran trung
Rep Power: 12 |
you can download free in the internet
October 23, 2013, 10:13 |
#13 |
Marie
Rep Power: 12 |
I have download the software following this way ; Starting FLUENT using the SDK 7.0 Command Prompt Window 1. Open up the SDK Command Window. This is required as this will set the compiler environment variables. 2. Choose the Start Menu > All Programs > Microsoft Windows SDK v7.0 > CMD 3. Launch FLUENT 14.5 from this window. (and chose 2D configuration) I add my working directory (directory where my .c file reside) and then I launch Fluent. I try then to compile my UDF (define/userdefine/functions/compiles/add and then load) and I got this error-message : > Opening library "C:\Users\...ex_files\dp0\FFF\Fluent\libudf\ntx86\ 2d\libudf" Error : The UDF library you are trying to load (libudf) is not compiled for 2d on the current plattform (Win64) + I have a nmake error + The system can t find the data. Do you have any idea where does it come from? |
Display Modes | |
what does FLUID_THREAD_P(t) macro do in udf? | borhan_sd@yahoo.com | Fluent UDF and Scheme Programming | 2 | June 10, 2013 06:49 |
DPM UDF particle position using the macro P_POS(p)[i] | dm2747 | FLUENT | 0 | April 17, 2009 02:29 |
need help whith hooking UDF and DEFINE_INIT macro | cax | FLUENT | 3 | June 6, 2006 13:35 |
-What udf macro for boiling - | thomas | FLUENT | 6 | January 19, 2004 08:31 |
DEFINE_DPM_OUTPUT macro UDF HELP | Puneet | FLUENT | 3 | November 28, 2003 11:55 |
