Hi
I can interpret without error. but during initializing appear the error: FLUENT received fatal signal (ACCESS_VIOLATION) 1. Note exact events leading to error. 2. Save case/data under new name. 3. Exit program and restart to continue. 4. Report error to your distributor. Although i can Compil it completely but in interaction box donot exist any UDF and fluent give the error: no udf have been loaded. Have you suggestion, kindly? |
From Fluent help:
The UDF make error because of writing fr om_index instead of from_index. I compiled it and that was the only problem. |
setting Solve/Set/Expert in Ansys 14.5
Can you please help me setting it in ansys 14.5 ... I dont have Set or Expert in Solve link...
Also I am using DEFINE MASS TRANSFER .. but by default ansys has linearized mass transfer... I basically want to change it in Solve/Set/Expert Please Help,:confused: |
hi Djn
To access the TUI in fluent, once your fluent programme is up, key "enter" at the main page. from there, you can then access the tui command. |
hamed.moradkhani@yahoo.com
do this procedure:
1.define->user-defined->functions->interprated.. interprate the ().c file 2.type on the command window of fluent solve(press enter) set(press enter) expert(press enter) answer for the 4 comming questions respectively are: no-yes-no-yes after these 2 steps u can hook the udf from phase intraction->mass tab->user defined->selecting udf... now you can start runing calculation let me inform about ur results tanx |
Hi. I try your method for hooping a DEFINE_MASS_TRANSFER udf for heta pipe simulation. The udf build and load successfully, but i can't hook it at the phase interaction tab. Any help is highly appreciated. |
