November 21, 2013, 02:25 |
UDF for variable temperature with time
Çağlar Coşkun
Rep Power: 14 |
Hello
I have a UDF, which varies the temperature according to the temperature at a certain point in the model. I write the coordinates of the point to the UDF where I want to check the temperature and the UDF varies the temperature of a wall with time according to that. I have a dummy model (a cube) to test the UDF. I write the coordinates of center of the cube and it seems to work fine. However, when I change my dummy model with a different one, all the things go wrong. What might be the problem? |
November 21, 2013, 16:46 |
majid
Rep Power: 15 |
Hi
Is it possible to help me to write UDF for Inlet gas temperature varying with time?I have equation of tempratue vs time. |
November 22, 2013, 13:35 |
François Grégoire
Rep Power: 17 |
majidmng, here is an example:
#include "udf.h" DEFINE_PROFILE(Tinlet, thread, position) { face_t f; real t = CURRENT_TIME; begin_f_loop(f, thread) { F_PROFILE(f, thread, position) = 100 + t; } end_f_loop(f, thread) } |
November 24, 2013, 05:04 |
Çağlar Coşkun
Rep Power: 14 |
Any help, idea, thought, opinion??
November 24, 2013, 15:38 |
Rick
Rep Power: 26 |
November 26, 2013, 03:29 |
#6 | |
Çağlar Coşkun
Rep Power: 14 |
What I am trying to do is to generate a wall temperature profile. I fitted a piecewise linear function to my actual temperature plot, and try to implement this function as a boundary condition to Fluent. My function is as follows: As you can see from the image above, there are a number of parts and every part is a linear function. The transitions in parts 1-3 are dependent in time, such as 1. part for first 3.5 minutes, 2. part for next 2 minutes etc. The duration of 4. part is controlled by a temperature at a certain point in my model. (there is actually a thermostat at this point). When the temperature at the thermostat reaches a certain value, the function jumps to the 5. part. The same story is also valid for 7. part. When the temperature at thermostat decreases to a value, the function jumps to the 1. part and whole of the function is redrawn in a periodic manner. This is my problem. The UDF that I wrote is as follows: Code:
#include "udf.h" #define PI 3.141592654 #define T1 268.00 #define T2 273.00 #define Xs 0.05 // Xs, Ys, Zs are the coordinates of point where the thermostat is located #define Ys 0.175 #define Zs -0.2 #define dx 0.005 real Dt0=20.0; real Dt1=3.5*60.0; real Dt2=2*60.0; real Dt3=5.5*60.0; real slope_1=27*60; real Dt4=3000*60.0; real Dt5=2*60.0; real Dt6=2.5*60.0; real Dt7=7.5*60.0; real slope_2=13.5*60; real Dt8=3000*60; real period=362210; real Tevapfz1=-27.9+273.15; real Tevapfz2=-20.8+273.15; real Tevapfz3=-20.3+273.15; real Tevapfz4=-20.6+273.15; real Tevapfz5=-18.9+273.15; real Tevapfz6=-22.5+273.15; real Tevapfz7=-23.7+273.15; real Tevapfz8=-26.1+273.15; real Tevapfz9=-27.9+273.15; real A=0.0; real B=-27.9+273.15; real Evap_time=0.0; real c_time=0.0; real Evap_time_stop=0.0; real Evap_time_work=0.0; real aralik=0.0; DEFINE_EXECUTE_AT_END(my_execute_at_end) { double Tave; double Tave0; Domain *d; Thread *t; cell_t c; FILE *pf; real x[2]; double cellt; d = Get_Domain(1); Tave=0.0; Tave0=Tave; cellt=0.0; c_time=CURRENT_TIME; if(c_time>Dt0) Evap_time=(c_time-Dt0)-floor((c_time-Dt0)/period)*period; if(c_time<=Dt0) Evap_time=0.0; thread_loop_c (t,d) { begin_c_loop (c,t) { C_CENTROID(x,c,t); if ((x[0]>(Xs-dx)) && (x[0]<(Xs+dx))) { if ((x[1]>(Ys-dx)) && (x[1]<(Ys+dx))) { if ((x[2]>(Zs-dx)) && (x[2]<(Zs+dx))) { cellt+=1.0; Tave+=C_T(c,t); } } } } end_c_loop (c,t) } Tave/=cellt; //Tave is the average temperature at the location of thermostat if (Evap_time<=Dt0) { A=0.0; B=Tevapfz1; aralik=0.0; } if ((Evap_time<Dt1)&&(Evap_time>=Dt0)) { A=(Tevapfz1-Tevapfz2)/(-Dt1); //A and B are the coefficients of linear functions at every part. B=Tevapfz1; aralik=1.0; } if ((Evap_time<Dt1+Dt2)&&(Evap_time>=Dt1)) { A=(Tevapfz2-Tevapfz3)/(-Dt2); B=(Tevapfz3*Dt1-Tevapfz2*(Dt1+Dt2))/(-Dt2); aralik=2.0; } if ((Evap_time<Dt1+Dt2+Dt3)&&(Evap_time>=Dt1+Dt2)) { A=(Tevapfz3-Tevapfz4)/(-Dt3); B=(Tevapfz4*(Dt1+Dt2)-Tevapfz3*(Dt1+Dt2+Dt3))/(-Dt3); Evap_time_stop=Evap_time; aralik=3.0; } if ((Evap_time<Dt1+Dt2+Dt3+Dt4)&&(Evap_time>=Dt1+Dt2+Dt3)) //The duration of this part is controlled by Tave { if (Tave<T2) { A=(Tevapfz4-Tevapfz5)/(-slope_1); B=(Tevapfz5*(Dt1+Dt2+Dt3)-Tevapfz4*(Dt1+Dt2+Dt3+slope_1))/(-slope_1); aralik=4.0; } if (Tave>=T2) { Dt4=Evap_time-Evap_time_stop; } } if ((Evap_time<Dt1+Dt2+Dt3+Dt4+Dt5)&&(Evap_time>=Dt1+Dt2+Dt3+Dt4)) { A=(Tevapfz5-Tevapfz6)/(-Dt5); B=(Tevapfz6*(Dt1+Dt2+Dt3+Dt4)-Tevapfz5*(Dt1+Dt2+Dt3+Dt4+Dt5))/(-Dt5); aralik=5.0; } if ((Evap_time<Dt1+Dt2+Dt3+Dt4+Dt5+Dt6)&&(Evap_time>=Dt1+Dt2+Dt3+Dt4+Dt5)) { A=(Tevapfz6-Tevapfz7)/(-Dt6); B=(Tevapfz7*(Dt1+Dt2+Dt3+Dt4+Dt5)-Tevapfz6*(Dt1+Dt2+Dt3+Dt4+Dt5+Dt6))/(-Dt6); aralik=6.0; } if ((Evap_time<Dt1+Dt2+Dt3+Dt4+Dt5+Dt6+Dt7)&&(Evap_time>=Dt1+Dt2+Dt3+Dt4+Dt5+Dt6)) { A=(Tevapfz7-Tevapfz8)/(-Dt7); B=(Tevapfz8*(Dt1+Dt2+Dt3+Dt4+Dt5+Dt6)-Tevapfz7*(Dt1+Dt2+Dt3+Dt4+Dt5+Dt6+Dt7))/(-Dt7); Evap_time_work=Evap_time; aralik=7.0; } if ((Evap_time<Dt1+Dt2+Dt3+Dt4+Dt5+Dt6+Dt7+Dt8)&&(Evap_time>=Dt1+Dt2+Dt3+Dt4+Dt5+Dt6+Dt7)) { if (Tave>T1) { A=(Tevapfz8-Tevapfz9)/(-slope_2); B=(Tevapfz9*(Dt1+Dt2+Dt3+Dt4+Dt5+Dt6+Dt7)-Tevapfz8*(Dt1+Dt2+Dt3+Dt4+Dt5+Dt6+Dt7+slope_2))/(-slope_2); aralik=8.0; } if (Tave<=T1) { Dt8=Evap_time-Evap_time_work; period=Dt1+Dt2+Dt3+Dt4+Dt5+Dt6+Dt7+Dt8; } } printf("CURRENT_TIME=%f\n", CURRENT_TIME); printf("c_time=%f\n", c_time); printf("Evap_time=%f\n", Evap_time); printf("period=%f\n", period); printf("Dt4=%f\n", Dt4); printf("Dt8=%f\n", Dt8); printf("Evap_time_stop=%f\n", Evap_time_stop); printf("Evap_time_work=%f\n", Evap_time_work); printf("Tave=%f\n\n", Tave); printf("EVAP-FZ-TEMPERATURE=%f\n", (A*Evap_time+B)); printf("ARALIK=%f\n\n", aralik); } DEFINE_PROFILE(evapfz_temp, thread, position) { face_t f; cell_t c; real x[2]; begin_f_loop(f, thread) { F_PROFILE(f, thread, position)= A*Evap_time+B; } end_f_loop(f, thread) } Thanks for your helps Last edited by CaglarCoskun; November 26, 2013 at 07:52. |
January 14, 2014, 08:57 |
Çağlar Coşkun
Rep Power: 14 |
Hello again
We have realized some mistakes about the algorithm and solved them, however the UDF still doesn't work. The main problem seems about parallelizing the UDF. The average temperature (designated as "Tave" in the code) are calculated different by every compute node. Some compute nodes even can't calculate a "Tave" value and their output becomes as "indefinite". Because of this confusion, some nodes go to the next part of the temperature profile and some of them don't so the whole process becomes messy. To solve the problem, I am trying to take the highest of all Tave's among all compute nodes. There is a UDF for a problem similar to mine in the following link, but I couldn't get any help from this code: http://aerojet.engr.ucdavis.edu/flue...df/node218.htm The final version of the code is given below. Can anyone help me about paralellizing this code? Code:
#include "udf.h" #define PI 3.141592654 #define T1 280.34 #define T2 281.32 #define Xs -0.820 // Xs, Ys, Zs are the coordinates of point where the thermostat is located #define Ys 0.347 #define Zs 0.279 #define dx 0.005 #define dy 0.005 #define dz 0.002 real Dt1=0.5*60.0; real Dt2=1.5*60.0; real Dt3=9*60.0; real slope_1=27.5*60; real Dt4=3000*60.0; real Dt5=1.5*60.0; real Dt6=2*60.0; real slope_2=10*60; real Dt7=3000*60; real Tevapfz1=-21+273.15; real Tevapfz2=-19.1+273.15; real Tevapfz3=-2.6+273.15; real Tevapfz4=4.8+273.15; real Tevapfz5=10+273.15; real Tevapfz6=-14+273.15; real Tevapfz7=-17+273.15; real Tevapfz8=-21+273.15; real A=0.0; real B=-21+273.15; real Evap_time=0.0; real c_time=0.0; real Evap_time_stop=0.0; real Evap_time_work=0.0; real aralik=0.0; real gz=0.0; FILE * fp; DEFINE_EXECUTE_AT_END(my_execute_at_end) { double cellt; double Tave; //The average temperature at the location of thermostat (calculated by one node) double Tave0; //Sum of all Tave's double Tave_total; //Highest of Tave's #if !RP_HOST Domain *d; Thread *t; cell_t c; real x[2]; d = Get_Domain(1); #endif Tave=0.0; Tave0=Tave; cellt=0.0; Tave_total=0.0; #if !RP_HOST thread_loop_c (t,d) { begin_c_loop (c,t) { C_CENTROID(x,c,t); if ((x[0]>(Xs-dx)) && (x[0]<(Xs+dx))) { if ((x[1]>(Ys-dy)) && (x[1]<(Ys+dy))) { if ((x[2]>(Zs-dz)) && (x[2]<(Zs+dz))) { cellt+=1.0; Tave+=C_T(c,t); } } } } end_c_loop (c,t) } Tave/=cellt; #if RP_NODE Tave_total=PRF_GRHIGH1(Tave); #endif #endif c_time=CURRENT_TIME; Evap_time=c_time-gz; if (Evap_time<Dt1) { A=(Tevapfz1-Tevapfz2)/(-Dt1); B=Tevapfz1; aralik=1.0; } if ((Evap_time<Dt1+Dt2)&&(Evap_time>=Dt1)) { A=(Tevapfz2-Tevapfz3)/(-Dt2); B=(Tevapfz3*Dt1-Tevapfz2*(Dt1+Dt2))/(-Dt2); aralik=2.0; } if ((Evap_time<Dt1+Dt2+Dt3)&&(Evap_time>=Dt1+Dt2)) { A=(Tevapfz3-Tevapfz4)/(-Dt3); B=(Tevapfz4*(Dt1+Dt2)-Tevapfz3*(Dt1+Dt2+Dt3))/(-Dt3); Evap_time_stop=Evap_time; aralik=3.0; } if ((Evap_time<Dt1+Dt2+Dt3+Dt4)&&(Evap_time>=Dt1+Dt2+Dt3)&&(Tave_total<T2)) { A=(Tevapfz4-Tevapfz5)/(-slope_1); B=(Tevapfz5*(Dt1+Dt2+Dt3)-Tevapfz4*(Dt1+Dt2+Dt3+slope_1))/(-slope_1); aralik=4.0; } if ((Evap_time<Dt1+Dt2+Dt3+Dt4)&&(Evap_time>=Dt1+Dt2+Dt3)&&(Tave_total>=T2)) { Dt4=Evap_time-Evap_time_stop; } if ((Evap_time<Dt1+Dt2+Dt3+Dt4+Dt5)&&(Evap_time>=Dt1+Dt2+Dt3+Dt4)) { A=(Tevapfz5-Tevapfz6)/(-Dt5); B=(Tevapfz6*(Dt1+Dt2+Dt3+Dt4)-Tevapfz5*(Dt1+Dt2+Dt3+Dt4+Dt5))/(-Dt5); aralik=5.0; } if ((Evap_time<Dt1+Dt2+Dt3+Dt4+Dt5+Dt6)&&(Evap_time>=Dt1+Dt2+Dt3+Dt4+Dt5)) { A=(Tevapfz6-Tevapfz7)/(-Dt6); B=(Tevapfz7*(Dt1+Dt2+Dt3+Dt4+Dt5)-Tevapfz6*(Dt1+Dt2+Dt3+Dt4+Dt5+Dt6))/(-Dt6); Evap_time_work=Evap_time; aralik=6.0; } if ((Evap_time<Dt1+Dt2+Dt3+Dt4+Dt5+Dt6+Dt7)&&(Evap_time>=Dt1+Dt2+Dt3+Dt4+Dt5+Dt6)&&(Tave_total>T1)) { A=(Tevapfz7-Tevapfz8)/(-slope_2); B=(Tevapfz8*(Dt1+Dt2+Dt3+Dt4+Dt5+Dt6)-Tevapfz7*(Dt1+Dt2+Dt3+Dt4+Dt5+Dt6+slope_2))/(-slope_2); aralik=7.0; } if ((Evap_time<Dt1+Dt2+Dt3+Dt4+Dt5+Dt6+Dt7)&&(Evap_time>=Dt1+Dt2+Dt3+Dt4+Dt5+Dt6)&&(Tave_total<=T1)) { Dt7=Evap_time-Evap_time_work; gz=Dt1+Dt2+Dt3+Dt4+Dt5+Dt6+Dt7; } fp=fopen("output.txt","a"); fprintf(fp, "CURRENT_TIME=%f\n", CURRENT_TIME); fprintf(fp, "Evap_time=%f\n", Evap_time); fprintf(fp, "Dt4=%f\n", Dt4); fprintf(fp, "Dt7=%f\n", Dt7); fprintf(fp, "A=%f\n", A); fprintf(fp, "B=%f\n", B); fprintf(fp, "Evap_time_stop=%f\n", Evap_time_stop); fprintf(fp, "Evap_time_work=%f\n", Evap_time_work); fprintf(fp, "Tave=%f\n\n", Tave); fprintf(fp, "EVAP-FZ-TEMPERATURE=%f\n", (A*Evap_time+B)); fprintf(fp, "ARALIK=%f\n\n", aralik); fprintf(fp, "Tave_total=%f\n\n", Tave_total); fclose(fp); PRF_GSYNC(); } DEFINE_PROFILE(evapfz_temp, thread, index) { #if !RP_HOST real x[ND_ND]; real y; face_t f; begin_f_loop(f, thread) { F_CENTROID(x,f,thread); F_PROFILE(f, thread, index) = A*Evap_time+B; } end_f_loop(f, thread) #endif } Last edited by CaglarCoskun; January 15, 2014 at 03:08. |
January 15, 2014, 08:39 |
Rep Power: 13 |
Excuse me for the silly question but is your UDF ok when you run on only 1 core ? In your loops, it might be better if you use "else if". I recently encountered problems when using multiple "if" loops without using "else if". |
January 15, 2014, 09:15 |
#9 |
Çağlar Coşkun
Rep Power: 14 |
Hi.
Yes it works very well with 1 core but things become complicated when parallel processing is acitivated. I tried "else if" but nothing changed. |
Transient simulation not converging | skabilan | OpenFOAM Running, Solving & CFD | 14 | December 16, 2019 23:12 |
Extrusion with OpenFoam problem No. Iterations 0 | Lord Kelvin | OpenFOAM Running, Solving & CFD | 8 | March 28, 2016 11:08 |
Moving mesh | Niklas Wikstrom (Wikstrom) | OpenFOAM Running, Solving & CFD | 122 | June 15, 2014 06:20 |
UDF for a time varying temperature | majidmng | Fluent UDF and Scheme Programming | 0 | November 21, 2013 01:38 |
How to write k and epsilon before the abnormal end | xiuying | OpenFOAM Running, Solving & CFD | 8 | August 27, 2013 15:33 |
