January 15, 2014, 14:51 |
UDF for thermal conductivity
Bennia Ayoub
Rep Power: 12 |
Dear Freinds...
i want to define thermal conductivity of nanofluid , I wrote UDF but when i interpreted to fluent, it show me a message "temp definition shadows previous definition" what's mean ? PHP Code:
January 16, 2014, 11:20 |
Rep Power: 26 |
It means that the variable name "temp" is already in used somewhere else. Not in your file, but somewhere in Fluent's files.
This will probably not give a real problem, but to be sure, you could rename your variable name into something else. |
January 16, 2014, 15:17 |
Bennia Ayoub
Rep Power: 12 |
thank you pakk , i renamed the variable and the UDF work without problem thanks again
January 20, 2014, 11:08 |
Nanofluid properties
Rep Power: 12 |
did you use compile or interpret for the UDF? I'm trying to use UDF for properties in a similar case but didn't work with me
January 22, 2014, 03:46 |
#5 | |
Bennia Ayoub
Rep Power: 12 |
August 18, 2014, 05:15 |
Bennia Ayoub
Rep Power: 12 |
I used interpreted , compiled and the udf work perfectly
I need one simple udf code for effective thermal conductivity of nanofluid | mvf | Fluent UDF and Scheme Programming | 1 | February 10, 2017 19:05 |
Anisotropic thermal conductivity UDF | Kwiaci | Fluent UDF and Scheme Programming | 2 | January 20, 2017 08:42 |
Thermal conductivity UDF | jack.s | Fluent UDF and Scheme Programming | 4 | February 29, 2012 11:57 |
UDF for effective thermal conductivity | Rashmi | FLUENT | 1 | November 6, 2007 20:08 |
Can wemodify effective thermal conductivity by UDF | FengYun | FLUENT | 2 | October 27, 2005 05:28 |
