2 degree of freedom in one direction UDF
I am doing simulation for flow around free oscillating cylinder. The cylinder was attach with the mass by spring which can be consider as 2 DOF system in one direction (y direction) not 1DOF for each (x, y direction). I using SDOF in Fluent for single degree of freedom case and it was working fine. But when it's come to 2 DOF, I have no idea how to start. I am very grateful if anybody can give me some suggestion how to start. Best Regards |
You can use the 6dof solver and create an udf with body properties and use the following lines to have restricted motion:
Transational motion in x direction is not allowed: Code:
prop[SDOF_ZERO_TRANS_X] = TRUE; Code:
prop[SDOF_ZERO_TRANS_X] = FALSE; Code:
prop[SDOF_ZERO_TRANS_Y] = TRUE; Code:
prop[SDOF_ZERO_TRANS_Y] = FALSE; Code:
prop[SDOF_ZERO_TRANS_Z] = TRUE; Code:
prop[SDOF_ZERO_TRANS_Z] = FALSE; Code:
prop[SDOF_ZERO_ROT_X] = TRUE; Code:
prop[SDOF_ZERO_ROT_X] = FALSE; Code:
prop[SDOF_ZERO_ROT_Y] = TRUE; Code:
prop[SDOF_ZERO_ROT_Y] = FALSE; Code:
prop[SDOF_ZERO_ROT_Z] = TRUE; Code:
prop[SDOF_ZERO_ROT_Z] = FALSE; |
1 Attachment(s)
Thank Daniele,
I have used this SDOF Macro already for Single degree of cylinder system I have done before and I quite familiar with SDOF Macro. But now I am doing 2DOF in 1 direction, that, the cylinder in the flow domain will be attached with a Mass (see attachment). Do you think in Fluent they have a Macro for this or I have to write my own UDF for this case. Linh |
