UDF to change heat transfer coefficient with temperature diff
Old   March 17, 2014, 09:46
Default UDF to change heat transfer coefficient with temperature diff
Yasser
eng_yasser_2020 is on a distinguished road
Dear, all
I am using FLUET to model a two concentric cylinders (Steady-state & 2-D). The gap between cylinders is filled with gas. I want to add a boundary condition (convection boundary) in the wall between the gas, inner and outer cylinder. I have a convection coefficient as a function of "Rayleigh No. = f(Th-Tc)" not a constant value. My problem is:
- How to write a UDF for the convection coefficient which is a function in gas properties (thermal conductivity, visco, Cp, .....) and it is also a function in temperature difference (Th-Tc)??
- I mean how to write a UDF uses the material properties like (k, Cp, meu,....)???. and uses temperature diff. of two material (Th[solid]-Tc[gas])??
Thanks all
eng_yasser_2020 is offline   Reply With Quote
Question about heat transfer coefficient setting for CFX Anna Tian CFX 1 June 16, 2013 06:28
heat transfer coefficient udf alighasemian Fluent UDF and Scheme Programming 0 June 6, 2012 06:04
Heat Transfer Coefficient in Compressible Flow 3D turbine cascade Karkoura CFX 0 March 10, 2011 15:35
Flow around pipes - heat transfer coefficient on the wall of pipe doodek Main CFD Forum 2 November 23, 2009 08:48
Question on heat transfer coefficient!!! Benny FLUENT 7 June 7, 2005 09:25
