change a variable in dissipation tem of turbulence model
Old   March 28, 2014, 08:31
Unhappy change dissipation rate of kinetic energy in k-w SST turbulence model
Ali.E
behest is on a distinguished road
Hello all,
I want to modify the dissipation rate of kinetic energy equation by UDF. Which macro can be used? Is it possible to use DEFINE_SOURCE for definning new dissipation rate?
Actually, I must change the formulation of dissipation rate of k-equation and then, Fluent uses the modified dissipation term instead of itselfs. My turbulence model is k-w SST and I just manipulate Y_k (dissipation rate of k).
Original: Y_k=ro*beta_s*k*w;
Modified: Y_k=ro*beta_s*k*w/delta; (delta is wall distance)
It would be appriciated if anyone makes a comment to how I do this task.
behest is offline   Reply With Quote
Use of k-epsilon and k-omega Models Jade M Main CFD Forum 40 January 27, 2023 07:18
gamma-ReTheta turbulence model for predicting transitional flows FelixL OpenFOAM Programming & Development 123 August 30, 2022 11:50
Modified k-e turbulence model UDF Travis Fluent UDF and Scheme Programming 7 November 11, 2018 20:21
eddy dissipation model: combustion doesn't occur roukaia FLUENT 0 December 24, 2011 09:10
emag beta feature: charge density charlotte CFX 4 March 22, 2011 09:14
