UDF for Vortex-Induced Vibrations debug
Hello to everybody;
Now I am investigating about VIV using tappered cylinders (3D); I am using 2-way FSI but the calculations are so slow (LES-WALE model in CFD and non-linear calculation in Transient Structural). I really need to do these calculations faster, so I think in use an UDF for VIV. Searching in the web, I found the next code, originally for a 2D problem: Quote:
The second issue is a simple question: Is it possible to use this code in my 3D problem, or I will have to adapt the code? Thank you very much. Bests regards. |
I am also looking for UDF for 2D and 3D case... If you found the solution please share... n_bkhan@yahoo.com Thanks Regards Niaz |
Hi, I know this is an old problem, but the problem you may have had is trying to interpret the udf. Some macros such as those for dynamic meshes do not interpret, but rather are compiled.
On that note, if you got it to work, could you please share your UDF with me? I am attempting this problem as well to get familiar with dynamic meshing. Thank you in advance. |
I used the UDF #include "udf.h" static real v_prev = 0.0; DEFINE_CG_MOTION(osc,dt,vel,omega,time,dtime) { Thread *t; Domain *d = Get_Domain(1); real x_cg[3], force[3], moment[3]; real accl, dv; real mass = 0.2; real wn = 12.0; real k= mass * wn*wn; real c = 2*mass*wn*0.00; int i; NV_S(vel, =, 0.0); NV_S(omega, =, 0.0); t = DT_THREAD(dt); for(i=0;i<3;i++) x_cg[i]=DT_CG(dt)[i]; Compute_Force_And_Moment(d, t, x_cg, force, moment, TRUE); force[1] += -k*x_cg[1] - c*vel[1]; accl = force[1]/mass; dv = accl*dtime; v_prev+=dv; vel[1] = v_prev; printf("Computed force: %g \n", force[1]); printf("Velocity: %g\n", vel[1]); } DEFINE_CG_MOTION(osc_inert,dt,vel,omega,time,dtime ) { vel[0] = 0.0; vel[1] = v_prev; } Yes you are right the issue is with the intrepret. I successfully run the udf using compiler for 2D problem but i dont know whether it will run on 3D or not. I have 2 more questions 1. how to change the above UDF to forced oscillation to find VIV forces 2. How to measure amplitude and forces... I know the above mentioned UDF calculate the forces(printf("Computed force: %g \n", force[1]; printf("Velocity: %g \n", vel[1]);) but I dont know where it will be available in FLUENT ... I am also very beginner to the dynamic mesh study. My problem is exactly same like your problem. We can share study with each other if you agree. My name is niaz and email n_bkhan@yahoo.com Thanks in advance. Best Regards Niaz |
Hi esho_adelaide, were you able to get this working? I am trying this udf for VIV of a 2D cylinder but the cylinder is not moving?
Thanks, please help me |
