Does CX_Interpret_String work in parallel?
Old   June 28, 2014, 11:17
Default Does CX_Interpret_String work in parallel?
Manuel
86lolo is on a distinguished road
Hello guys
I am having trouble with that function.
I have an EXECUTE_ON_DEMAND which evaluates some conditions of my problem, and based on the result, it will keep'on iterating. I need to iterate over time-steps untill a certain condition gets reached
Therefore I had something like:
while(my_condition_not_satisfied) /*more iterations needed*/
 CX_Interpret_String("/solve/dti 100 20");
 evaluate_again_condition;
It did not work. Seems that this function does not like general fluent commands. Instead, it is necessary to use "(physical-time-steps 100 20)" as the string. General TUI commands do not work, only those scheme commands wrapped in brackets. I wonder why.
Then I even thought of using the scheme command "ti-menu-load-string" to load any string you want, putting it inside the CX_Interpret_String and. Sounds ridiculous, (a string interpreter inside a string interpreter), but worth trying...
That didn't work either. Fluent will crash, entering in no-response mode, without even printing in the console why.
ANYWAY, I tried to continue with (physical-time-steps) and make it to work in parallel... big mistake. It didn't work. CX_Interpret_String gives me error:
Error: eval: unbound variable
Error Object: physical-time-steps
(with same code which worked in serial mode). Fluent manual is not explicit whether this function should be protected by #if ! directives. Anyway, I have tried all the combinations and still I get the same.
I think my problem is solvable by scheme commands (a scheme DO loop and rp-variable passing to UDFs to evaluate the condition), but I'd really like to try by UDF first, scheme is tedious, user-unfriendly and hard-to-write.
Has anyone used CX_Interpret_String in parallel Fluent?
Is there any documentation about it? I found nothing in Ansys UDF Manual. I have also found around that exists CX_Interpret_String_to_String and CX_Message functions, but I don't know what they are for and where is documentation about them.
Thanks in advance
86lolo is offline   Reply With Quote
Old   June 29, 2014, 21:22
gearboy is on a distinguished road
I also encountered such thing. I prefer to writing scheme command and use "Execute command" menu to perform it in parallel mode.
gearboy is offline   Reply With Quote
Old   June 30, 2014, 04:36
Manuel
Do you mean in Calculation Activities panel?
parallel, scheme, udf
error while running in parallel using openmpi on local mc 6 processors suryawanshi_nitin OpenFOAM 10 February 22, 2017 21:33
Parallel processing problem newbie29 OpenFOAM Running, Solving & CFD 1 June 22, 2012 04:23
CFX parallel multi-node jobs fail w/ SLURM on Ubuntu 10.04 danieru CFX 0 February 17, 2012 06:20
HP MPI warning...Distributed parallel processing Peter CFX 10 May 14, 2011 06:17
Cases with small length scale work fine on a single processor but fail in parallel adona058 OpenFOAM Bugs 5 April 17, 2009 04:41
