mesh morpher/optimizer
Old   November 28, 2011, 11:08
Unhappy mesh morpher/optimizer
Ava
scsasha is on a distinguished road
Hi every body.
I have a problem with my UDF for defining the objective function for design optimization of an airfoil. Here is my UDF:
#include"udf.h"
#include"dynamesh_tools.h"
#include"morpher.h"
# define ZONEID 3
DEFINE_ON_DEMAND(objective_function)
real x_cg[2];
real f_glob[2];
real m_glob[2];
real drag=0.0;
Domain *domain;
Thread *thread;
domain=Get_Domain(1);
thread = Lookup_Thread(domain,ZONEID);
x_cg[0] = 0;
Compute_Force_And_Moment(domain,thread,x_cg,f_glob ,m_glob,TRUE);
drag=f_glob[0]*0.9962+f_glob[1]*0.08716;
RP_Set_Real(
"morpher/objective_function",drag);
It is compiled successfully but when I check it through execute on demand or when I use it in the optimization, I receive this error message:
Error: rp-var-value-local-set!: undefined variable
Error Object: morpher/objective_function
I use win 64 bit and Visual Stodio 2010 and Fluent 13. I would be happy if anybody can help me with this problem.
scsasha is offline   Reply With Quote
Old   November 29, 2011, 10:42
Default http://www.cfd-online.com/Forums/newreply.php?do=newreply&noquote=1&p=333824#
fox000002's Avatar
fox000002 is on a distinguished road
Execute following command before loading your own UDF.
/define/enable-mesh-morpher-optimizer? yes
fox000002 is offline   Reply With Quote
Old   December 1, 2011, 10:51
Ava
Thank you so much but it still doesnt work!
Old   December 1, 2011, 11:02
Ava
Old   December 2, 2011, 05:52
fox000002's Avatar
The rpvar name is wrong.
RP_Set_Real("morpher/objective-function",drag);
Old   December 5, 2011, 05:33
Thumbs up
Ava
Thank you so much for your help. It is working now!
Old   January 11, 2013, 11:01
Ibrar is on a distinguished road
Hi all
I think you people are very good with optimization
I am also trying to optimize the shape of chemical reactor. I have some basic questions
1) what is the meaning of parameters in the optimizer windows??
2) how can we set their max and minimum values?
3) I am solving 2D axisymmetic flow through a pipe" with a chemical reaction taking place inside it" and i want to optimize the shape of that pipe"optimized shape would be something like combination of nozzle diffuser type" should I define the optimization region over the whole axisymmetric domain or just on the area close to the wall.
4) i leant from the blog that people are interfacing matlab with fluent to do geometric optimization, I want to know why they are not using these biult in optimizer. of course there are certain limitation can you please give a take of that??
5) finally some idea of how to link matlab with fluent
Thanks in advance for your rime and concern
Ibrar
Ibrar is offline   Reply With Quote
Old   August 31, 2014, 18:23
Syavash Asgari
syavash is on a distinguished road
Originally Posted by scsasha View Post
Hi every body.
#include"udf.h"
#include"morpher.h"
# define ZONEID 3
real x_cg[2];
real f_glob[2];
real m_glob[2];
real drag=0.0;
Domain *domain;
Thread *thread;
x_cg[0] = 0;
RP_Set_Real(
Dear scsasha
Could you tell us How many control points you have considered around the airfoil?
Thanks
syavash is offline   Reply With Quote
[ICEM] surface mesh merging problem everest ANSYS Meshing & Geometry 44 April 14, 2016 06:41
[ICEM] Problem making structural mesh on a surface froztbear ANSYS Meshing & Geometry 1 November 10, 2011 08:52
[snappyHexMesh] snappyHexMesh won't work - zeros everywhere! sc298 OpenFOAM Meshing & Mesh Conversion 2 March 27, 2011 21:11
Meshing aifoil in ICEM student123a ANSYS Meshing & Geometry 13 December 8, 2010 10:40
2d irregular grid Remy Main CFD Forum 1 December 22, 2008 04:49
