September 2, 2019, 15:08 |
UDS for solid temperature
I am working on porous media with local thermal non equilibrium model. (ANSYS Fluent), and I use a UDS for solid temperature. My question is : did I need to define a new thread (for the solid cell zone ) in my solid source term UDF ? thank you. |
September 3, 2019, 04:07 |
Alexander
Rep Power: 34 |
your question is not clear
you may try to post here your code, so people could understand what thread are you talking about best regards |
April 2, 2021, 14:21 |
khedidja
Rep Power: 6 |
did you mean that you implement USED to solve radiation equation solid source term . if yes please contact me in my email, I work on solar receiver.
khadidja.mezzoued@gmail.com |
April 2, 2021, 14:24 |
khedidja
Rep Power: 6 |
did you mean that you implement UDS to solve radiation equation solid source term . if yes please contact me in my email, I work on solar receiver.
April 2, 2021, 14:35 |
#5 | ||
khedidja
Rep Power: 6 |
hi i'm working on coupled heat radiation transfer in porous media with with local thermal non equilibrium model. (ANSYS Fluent). i implemented the P1 model for the radiation to compte the radiation source term in solid equation. my question is in UDf the temperature that called C_T(c,t) is for the fluid or for solid in this case. best regard |
April 2, 2021, 22:04 |
#6 | |
Yasser Selima
Rep Power: 19 |
The temperature of the fluid and solid will be the same C_T(c,t) |
@iliasbkh |
UDF to get the average temperature of a face and use it to define a property | gdb | Fluent UDF and Scheme Programming | 19 | November 3, 2022 03:11 |
Shadow Wall and temperature | norger | FLUENT | 10 | September 28, 2019 11:43 |
temperature gradient source term in uds | cfd_mech | FLUENT | 0 | July 27, 2014 04:55 |
How to get free stream temperature in boundary condition | saharesobh | FLUENT | 0 | October 9, 2012 17:12 |
Inlet won't apply UDF and has temperature at 0K! | tccruise | Fluent UDF and Scheme Programming | 2 | September 14, 2012 06:08 |
