change fluent parameter via udf
Like Tree1Likes
  • 1 Post By pakk
Old   September 17, 2013, 05:01
Default change fluent parameter via udf
Manuel Lorenz
lorenz is on a distinguished road
I use in my simulation some input parameters (for example for the inlet temperature or for the flow rate ratio of an outflow). I have found out how to acess these variables via scheme. But is there also a way to access and change these parameters with an udf function?
Thanks...
lorenz is offline   Reply With Quote
Old   September 23, 2013, 07:09
Christopher Hershey
Hershey is on a distinguished road
Yes, it is possible. So take the following example:
In FLUENT, define your scheme variable 'x'
(rp-var-define 'x 0 'integer #f)
Now you have defined an integer variable x with 0 as its value.
To set this in a UDF
RP_Set_Integer("x",3)
Now you have set the scheme variable x to 3.
Two notes: Your variable must be a string in the UDF and the Integer portion changes based on the type of variable you have.
You can also access your variable in a UDF by:
y = RP_Get_Integer("x");
Now y is equal to your value set in the scheme variable x.
Please respond if you need more help.
Hershey is offline   Reply With Quote
Old   January 19, 2015, 09:47
Default How to access input parameters
Anders Simonsen
ASimonsen is on a distinguished road
Hello.
lorenz - how did you access the input parameters via scheme?
Regards Anders
ASimonsen is offline   Reply With Quote
Old   January 20, 2015, 03:14
pakk will become famous soon enough
Look at the Fluent UDF manual. Section 3.6.2: Accessing a Scheme Variable in the Text Interface.
In this case, it would be:
(%rpgetvar ’x)
ASimonsen likes this.
pakk is offline   Reply With Quote
UDF to record FLUENT Solver variables... mariachi Fluent UDF and Scheme Programming 11 September 24, 2019 00:07
Two questions on Fluent UDF Steven Fluent UDF and Scheme Programming 7 March 23, 2018 03:22
UDF interpret in Fluent wanghaojie Fluent UDF and Scheme Programming 1 February 3, 2012 14:51
Fluent UDF Discontinuous Motion lequi7 Fluent UDF and Scheme Programming 2 November 3, 2011 23:18
fluent UDF external library lapack problem Rick FLUENT 0 May 7, 2008 10:16
