February 23, 2015, 02:53 |
UDF for mass transfer in dryer
Rep Power: 11 |
Hello to all,
Anyone knows how to write a UDF for my problem I have a 2D fluidized bed dryer and moisture transfer from solid to fluid ,so we have mass transfer. I read the manual and i guess that i must use Define_Source and Define_Exchange_Property....but I'm new to this field and know a little about UDF Does anyone have knowledge about this problem? Tanx Best... |
March 5, 2015, 23:55 |
for mass transfer
Baradwaj B S
Rep Power: 11 |
Hi there,
Try using DEFINE_PROFILE and under that use F_PROFILE. The value u give to F_PROFILE will be the value of mass transfer. Like if u hook this to mass flow rate then the value of F_PROFILE value will be the value of mass flow rate (kg/s). Good luck. |
Foam::error::PrintStack | almir | OpenFOAM Running, Solving & CFD | 91 | December 21, 2022 04:50 |
UDF for hear transfer coefficient in non-thermal equilibrium porous meda | sheeko | Fluent UDF and Scheme Programming | 8 | January 1, 2020 23:43 |
Mass transfer UDF expecting void return | Quinos | Fluent UDF and Scheme Programming | 0 | January 8, 2014 18:36 |
UDF and UDM for heat transfer coeff. calculation | Schluckner | Fluent UDF and Scheme Programming | 1 | October 20, 2013 13:39 |
Error finding variable "THERMX" | sunilpatil | CFX | 8 | April 26, 2013 07:00 |
