UDF problem
I'm a user of fuel cell addon-module, and I'm trying to get volume averaged relative humidity. and I got an error form my customized code.
My code was compiled well but when it stared to calculate, error came up. I think the reason of the error was C_YI(c,t,i_h2o). When I deleted this term, there was no error. Can't it be used below begin_c_loop macro?? or Is dimension wrong? please help me! below is my code real Membrane_Conductivity(real lam, cell_t c, Thread *t) { Domain *d; real volume; real vol_tot = 0.0; real P_sat; real C_h2o = 0.0; real TT; real RH_avg = 0.0; int i=0; real MC_h2o; real MW_h2o = mw[i_h2o]; real RH_av; real T = C_T(c,t); real Ru = 8.314; real x = 6.0; /* doping level*/ real Ea = -619.6*x+21750; real a = (168*x*x*x)-(6324*x*x)+(65750*x)+8460; real b; real sigma; int zt = get_fc_zone_type(t->id); /*d = Get_Domain(ROOT_DOMAIN_ID);*/ d = Get_Domain(1); thread_loop_c(t,d) { begin_c_loop(c,t) { volume = C_VOLUME(c,t); TT = C_T(c,t); P_sat = Get_P_sat(TT); MC_h2o = C_YI(c,t,i_h2o); /*C_h2o = C_YI(c,t,i_h2o)*C_R(c,t)/mw[i_h2o];*/ C_h2o = MC_h2o*C_R(c,t)/MW_h2o; if (zt == aca_zone || zt == cca_zone) { vol_tot += volume; RH_avg += (R_Gas*TT/P_sat*C_h2o)*volume; } } end_c_loop(c,t) RH_avg /= vol_tot; } RH_av = RH_avg; b = 1+(0.01704*T-4.767)*RH_av; sigma = a*b/T*exp(-Ea/Ru/T); return sigma; |
When you started calculation, what error was thrown exactly? |
error message was like this.
unable to read the cmd header on the pmi context, Error = -1 999999 (..\src\mpsystem.c@1173): mpt_read: failed: errno = 10054 999999: mpt_read: error: read failed trying to read 4 bytes: No such file or directory unable to read the cmd header on the pmi context, Error = -1 received suspend command for a pmi context that doesn't exist: unmatched id = 7 received suspend command for a pmi context that doesn't exist: unmatched id = 6 received suspend command for a pmi context that doesn't exist: unmatched id = 5 received suspend command for a pmi context that doesn't exist: unmatched id = 4 job aborted: rank: node: exit code[: error message] 0: x70-jof7ksxthyb: -1073741819: process 0 exited without calling finalize 1: x70-jof7ksxthyb: -1073741819: process 1 exited without calling finalize 2: x70-jof7ksxthyb: -1073741819: process 2 exited without calling finalize 3: x70-jof7ksxthyb: -1073741819: process 3 exited without calling finalize 4: x70-jof7ksxthyb: -1073741819: process 4 exited without calling finalize 5: x70-jof7ksxthyb: -1073741819: process 5 exited without calling finalize 6: x70-jof7ksxthyb: -1073741819: process 6 exited without calling finalize 7: x70-jof7ksxthyb: -1073741819: process 7 exited without calling finalize received suspend command for a pmi context that doesn't exist: unmatched id = 3 received suspend command for a pmi context that doesn't exist: unmatched id = 2 received suspend command for a pmi context that doesn't exist: unmatched id = 1 The Parallel FLUENT process could not be started. |
I am not sure exactly about the cause. I doubt about partitioning.
You may use: 1.In FLUENT select the "Parallel" menu 2.Choose "Auto Partition" 3.Unselect "Case File" 4.Select "Metis" as the partition method 5.Choose OK |
I've changed parallel menu as you said , but it still gives error message.
Even serial processing case throws error message. When C_YI term was deleted, the case ran well.... |
Not sure, but the error seems related to parallel computing only. http://stackoverflow.com/questions/1...ontext-error-1 Also try initializing C_YI terms with 0.0 |
