About linearizing the source term in ZGB cavitation model
Old   June 1, 2016, 03:41
Default About linearizing the source term in ZGB cavitation model
Pavan Mantripragada
mppavan is on a distinguished road
I am coding for an UDF for ZGB cavitation model. Though the solution converges well but the values are not correct. I googled about the issue and they say that you must linearize the source term. How is does this affect the solution. What should I do for linearizing it?
Thanks,
mppavan is offline   Reply With Quote
cavitation model, linearization, source udf, udf and programming, zgb model
[OpenFOAM.org] Error creating ParaView-4.1.0 OpenFOAM 2.3.0 tlcoons OpenFOAM Installation 13 April 20, 2016 17:34
[Other] How to use finite area method in official OpenFOAM 2.2.0? Detian Liu OpenFOAM Meshing & Mesh Conversion 4 November 3, 2015 03:04
[Other] Adding solvers from DensityBasedTurbo to foam-extend 3.0 Seroga OpenFOAM Community Contributions 9 June 12, 2015 17:18
[swak4Foam] swak4Foam-groovyBC build problem zxj160 OpenFOAM Community Contributions 18 July 30, 2013 13:14
DxFoam reader update hjasak OpenFOAM Post-Processing 69 April 24, 2008 01:24
