November 4, 2017, 03:06 |
UDF for flow at the outlet of pipe
Shilpa
hi everyone!
I am simulating flow through a porous medium. one of the fluid is flowing in the pipe containing the porous medium at a constant velocity. At the outlet end, there is no fluid coming out until the outlet gauge pressure reaches 400 psi. after which the flow starts. Which boundary conditions do I apply at the outlet? Do I need a user defined function at the outlet? Shilpa Nandwani |
UDF to adjust pressure outlet | a.lynchy | FLUENT | 4 | February 15, 2021 00:50 |
[DesignModeler] DesignModeler Pipe within pipe | shields | ANSYS Meshing & Geometry | 13 | November 25, 2018 22:14 |
Fluent UDF implementation of a 1D wave equation (Convective BC) at an outlet | balav94 | Fluent UDF and Scheme Programming | 0 | September 17, 2016 07:30 |
UDF Defining VOF Free Surface at Outlet | Alex | Fluent UDF and Scheme Programming | 13 | August 8, 2012 16:50 |
steam flow in a pipe driven by a pressure gradient between inlet and outlet | SalvoCalvo | COMSOL | 0 | March 11, 2010 06:52 |
