problem when I interpret my UDF for granular viscosity
Old   May 6, 2015, 13:00
Post problem when I interpret my UDF for granular viscosity
javier
spanish is on a distinguished road
I'm doing my degree’s final project and I need to create an UDF for granular viscosity in Eulerian model.
I have two UDF's for granular viscosity, but both have the same problem when I interpret it.
The UDFs are these:
1)
#include "udf.h"
DEFINE_PROPERTY(Shear_Vis_Lun_modified,cell,thread )
real shear_vis_lun;
real strain_rate;
strain_rate= C_STRAIN_RATE_MAG(cell,thread);
shear_vis_lun = 11224*pow(strain_rate, (0.323-1));
return shear_vis_lun;
2)
#include "udf.h"
DEFINE_PROPERTY(solid_viscosity,cell, thread)
real mu;
real str=C_STRAIN_RATE_MAG(cell,thread);
mu=11224*pow(str,(0.323-1));
return mu;
The mistake that appears in fluent is the following:
cpp - I"/ansys_inc/v140/fluent/fluent14.0.0/src" - I"/ansys_inc/v140/fluent/fluent14.0.0/cortex/src" - I"/ansys_inc/v140/fluent/fluent14.0.0/client/src" - I"/ansys_inc/v140/fluent/fluent14.0.0/multiport/src" - I. DUDFCONFIG_H="<udfconfig.h>" "/home/jfernandez/Proyecto jfernandez/malla1/caso 1/solid viscosity.c"
Error: /home/jfernandez/Proyecto jfernandez/malla1/caso 1/solid viscosity.c: line2: syntax error.
I have to compile these UDFs but encountered other problems also.
I don`t know what would be better, to compile or to interpret.
If it would be better to compile; I would be able to show my problem as I do so.
It is very important for my project; I would really appreciate any help I can get.
Thank you beforehand.
spanish is offline   Reply With Quote
Old   May 8, 2015, 05:44
pakk will become famous soon enough
Are you able to interpret or compile other udfs? The ones from the manual for example?
pakk is offline   Reply With Quote
Old   May 8, 2015, 12:37
javier
Hello
I have to get to compile my UDFs mysteriously. I don't know how I did it, lol
But I have a new problem now. UDFs are so difficult
Thank you for your help
[ Moderator note: text below came from post that was in this thread: http://www.cfd-online.com/Forums/flu...ure-model.html ]
Hello
I need to create an UDF for granular viscosity. I have to try with differents UDFs but I always have some problem.
Do you get to creat an UDF for granular viscosity?
Last edited by wyldckat; May 8, 2015 at 15:22. Reason: moved and merged posts on the same question
Old   May 11, 2015, 07:27
If you need help, you should ask a specific question. Right now it is not clear how anybody can help you.
Old   May 11, 2015, 10:28
javier
Hello
I'm going to try to explain better my case.
I have created two UDF's for granular viscosity. Both UDF's are up.
Firstly, I don't know if this UDF's are correct for granular viscosity in Eulerian model.
When I compile some of this UDF, I obtain the following:
[IMG]file:///C:\Users\javier\AppData\Local\Temp\msohtmlclip1\01 \clip_image002.jpg[/IMG]
And then, I build without problem.
Old   May 11, 2015, 10:29
javier
Then, I change settings,
Finally, when I start the calculation, It appear this message:
# Divergence detected in AMG solver :mp-x-momentum -> decreasing coarsening group size!
# Divergence detected in AMG solver :mp-x-momentum -> Increasing relaxation sweeps!
# Divergence detected in AMG solver : presure correction -> turning off correction scaling!
# Divergence detected in AMG solver : pressure correction -> Increasing relaxation sweeps!
Error: DIvergence detected in amg solver: pressure correction
Error Object: #f
I don't know how can I solve these problems.
I would appreciate your help
Thank you
Old   May 18, 2015, 12:00
javier
Hello again,
I think that I found the mistake. I changed the udf, fixing granular viscosity for check the udf, and the result was perfect
#include "udf.h"
real shear_vis_lun;
shear_vis_lun = 850;
Also, I created a UDF for viscosity on primary phase, using C_STRAIN_RATE_MAG(c,t) and the result was wrong. The error was the same (DIVERGENCE DETECTED....)
#include "udf.h"
DEFINE_PROPERTY(viscosity,c,t)
real visco;
visco = 380.18*pow(C_STRAIN_RATE_MAG(C,t),0.547-1.);
return visco;
I think the mistake is in strain rate function, but I don´t know how I can change this problem.
thanks in your advance.
best regards
Old   June 11, 2015, 10:40
javier
I solved my problem initialazing with a previous solution. Thank you for your help
compile error, granular viscosity, interpreted udf
Problem UDF for Turbulen viscosity fevi84 Fluent UDF and Scheme Programming 2 June 25, 2017 18:25
compile a udf or interpret it? ndabir Fluent UDF and Scheme Programming 1 July 14, 2012 02:49
UDF interpret in Fluent wanghaojie Fluent UDF and Scheme Programming 1 February 3, 2012 14:51
UDF using problem, error happens-heip!! Michael FLUENT 1 December 9, 2008 07:51
UDF variables F1, y / problem with UDF Fabian FLUENT 6 June 2, 2003 10:22
