syavash |
June 4, 2015 17:43 |
span-wise averaging
Hello mates,
I have developed a UDF which is able to perform span-wise averaging in the homogenous direction. It can be handy in LES or DNS simulation if one would want to plot span-wise averaged streamlines. Note that this UDF only works if there is already a time-averaged solution (Data sampling checked).
Enjoy!!
DEFINE_ON_DEMAND(Span_Averaged)
Domain *d = Get_Domain(1);
Thread *t0 = Lookup_Thread(d,ID); /* ID is of periodic BC */
Thread *t;
cell_t c;
face_t f;
double x[ND_ND],x2[ND_ND],xc[ND_ND];
double X, Y, u_mean, v_mean, w_mean, SUM_u, SUM_v, SUM_w, u_Averaged, v_Averaged, w_Averaged, TOL, temp1, temp2, temp3;
int counter = 0;
int counter2 = 0;
TOL = 2e-3;
SUM_u = 0.0;
SUM_v = 0.0;
SUM_w = 0.0;
#if !RP_HOST
begin_f_loop(f,t0)
F_AREA(x2,f,t0);
F_CENTROID(x,f,t0);
X = x[0];
Y = x[1];
counter2 +=1;
Message("face %d\n", counter2);
thread_loop_c(t,d)
if (FLUID_THREAD_P(t))
begin_c_loop(c,t)
C_CENTROID(xc,c,t);
if (ABS((xc[0] - X) / X) < TOL && ABS((xc[1] - Y) / Y) < TOL)
counter +=1;
u_mean = C_STORAGE_R(c,t, SV_U_MEAN)/delta_time_sampled;
v_mean = C_STORAGE_R(c,t, SV_V_MEAN)/delta_time_sampled;
w_mean = C_STORAGE_R(c,t, SV_W_MEAN)/delta_time_sampled;
SUM_u = SUM_u + u_mean;
SUM_v = SUM_v + v_mean;
SUM_w = SUM_w + w_mean;
end_c_loop(c,t)
if (counter > 0)
u_Averaged = SUM_u / counter;
v_Averaged = SUM_v / counter;
w_Averaged = SUM_w / counter;
temp1 = u_Averaged;
temp2 = v_Averaged;
temp3 = w_Averaged;
else
u_Averaged = temp1;
v_Averaged = temp2;
w_Averaged = temp3;
SUM_u = 0.0;
SUM_v = 0.0;
SUM_w = 0.0;
Message("counter %d\n", counter);
counter = 0;
begin_c_loop(c,t)
C_CENTROID(xc,c,t);
C_UDMI(c, t, 0) = u_Averaged;
C_UDMI(c, t, 1) = v_Averaged;
C_UDMI(c, t, 2) = w_Averaged;
end_c_loop(c,t)
end_f_loop(f,t0)
#endif
Note: The parameter "TOL" should be adjusted to make sure all the cells in the span-wise direction are taken into account!
Another point, this code only works with Hexa grids!
Regards
