Error in UDF for sinusoidal wave propagation at channel wall
I have the following UDF for sinusoidal wave propagation at channel wall. this UDF is intended to deform the channel wall thus causing the fluid motion inside the channel.
#include "udf.h" #include<stdlib.h> #include<math.h> #define AH 0.1 // Average Height of Channel #define XL 1.0 // Length #define WA 0.01 // Wave Amplitude #define PI 3.1415925 #define C 0.05 //Wave Speed #define Lambda 3.0 // wavelength #define XStep 0.001 #define XSize XL/XStep #define HStep 0.0001 #define HSize AH/HStep DEFINE_GRID_MOTION(peristaltic, domain, dt, time, dtime) { Thread *tf= DT_THREAD(dt); face_t f; float curr_time = CURRENT_TIME; //float xVec[XSize]; //based on XStep you can pre compute how much should be the vector dimension (number of elements in xVec, say 1000 (replace it here float xVec[1000]; xVec[0] = 0; int counter = 1; for (counter = 1; counter < XSize; counter++) xVec[counter] = xVec[counter - 1] + XStep; float hVec[1000]; //same as the case of xVec, compute the number and put the number here int i=1; begin_f_loop(f,tf) { curr_time = CURRENT_TIME; float sint = sin (2 * PI/Lambda * xVec[i] - C * curr_time); hVec[i] = AH * WA * sint; i = i + 1; } } After building the library the following errors in console appear. Build Time: Oct 12 2010 17:12:32 Build Id: 10703 Loading "c:\PROGRA~1\ANSYSI~1\v130\fluent\fluent13.0.0 \lib \fl_s1119.dmp" Done. > Deleted old libudf\ntx86\2d\libudf.dll 1 file(s) copied. (system "copy "c:\PROGRA~1\ANSYSI~1\v130\fluent"\fluent13.0. 0\sr c\makefile_nt.udf "libudf\ntx86\2d\makefile" ") 1 file(s) copied. (chdir "libudf")() (chdir "ntx86\2d")() # Generating ud_io1.h PeistalticUDFNEW.C ..\..\src\PeistalticUDFNEW.C(29) : error C2143: syntax error : missing ';' before 'type' ..\..\src\PeistalticUDFNEW.C(30) : error C2065: 'counter' : undeclared identifier ..\..\src\PeistalticUDFNEW.C(30) : error C2065: 'counter' : undeclared identifier ..\..\src\PeistalticUDFNEW.C(30) : error C2065: 'counter' : undeclared identifier ..\..\src\PeistalticUDFNEW.C(31) : error C2065: 'counter' : undeclared identifier ..\..\src\PeistalticUDFNEW.C(31) : error C2065: 'counter' : undeclared identifier ..\..\src\PeistalticUDFNEW.C(33) : error C2143: syntax error : missing ';' before 'type' ..\..\src\PeistalticUDFNEW.C(35) : error C2143: syntax error : missing ';' before 'type' ..\..\src\PeistalticUDFNEW.C(39) : error C2143: syntax error : missing ';' before 'type' ..\..\src\PeistalticUDFNEW.C(40) : error C2065: 'hVec' : undeclared identifier ..\..\src\PeistalticUDFNEW.C(40) : error C2065: 'i' : undeclared identifier ..\..\src\PeistalticUDFNEW.C(40) : error C2109: subscript requires array or pointer type ..\..\src\PeistalticUDFNEW.C(40) : error C2065: 'sint' : undeclared identifier ..\..\src\PeistalticUDFNEW.C(41) : error C2065: 'i' : undeclared identifier ..\..\src\PeistalticUDFNEW.C(41) : error C2065: 'i' : undeclared identifier ..\..\src\PeistalticUDFNEW.C(43) : fatal error C1075: end of file found before the left brace '{' at '..\..\src\PeistalticUDFNEW.C(36)' was matched Done. Please I need some useful suggestion to get rid of these errors. I am a beginner in ANSYS Fluent and my brother wrote this UDF for me whose is a computer engineer. I think the errors are due to syntex difference?? |
