April 7, 2015, 15:16 |
UDFs parallel errors
saad
Hey please i want you to help i m in trouble with my UDFs it s about simulations in parallel mode
In fact, when I launch the simulation from the locale (cluster) my UDFs compile perfectly but when i do it in the parallel mode my UDFs don't compile and if i have these kind of errors :/ Could you help me pleaaase : make[1]: Entering directory `/home_nfs/USERS/PE_EX/vignaesh.subramaniam/Upload/Fluent/libudf/lnamd64/2ddp' # Generating udf_names.c because of heatfluxudf_linear.c make[2]: Entering directory `/home_nfs/USERS/PE_EX/vignaesh.subramaniam/Upload/Fluent/libudf/lnamd64/2ddp' make libudf.so "CFLAGS=-D_lnamd64 -D_GNU_SOURCE -fpic -shared -ansi -Wall -O -DPTR_RESTRICT= " "LDFLAGS=-shared -lm" make[3]: Entering directory `/home_nfs/USERS/PE_EX/vignaesh.subramaniam/Upload/Fluent/libudf/lnamd64/2ddp' # Compiling udf_names.o because of udf_names.c udfconfig.h cc -D_lnamd64 -D_GNU_SOURCE -fpic -shared -ansi -Wall -O -DPTR_RESTRICT= -I/Applications/ansys_inc/v150/fluent/fluent15.0.0/`expr "\`pwd\`" : '.*/\(.*\)/[23].*'`/`basename "\`pwd\`"` -I/Applications/ansys_inc/v150/fluent/fluent15.0.0/src -I/Applications/ansys_inc/v150/fluent/fluent15.0.0/cortex/src -I/Applications/ansys_inc/v150/fluent/fluent15.0.0/client/src -I/Applications/ansys_inc/v150/fluent/fluent15.0.0/tgrid/src -I/Applications/ansys_inc/v150/fluent/fluent15.0.0/multiport/src -I/Applications/ansys_inc/v150/fluent/fluent15.0.0/multiport/mpi_wrapper/include -I/Applications/ansys_inc/v150/fluent/fluent15.0.0/multiport/mpi_wrapper/src -I. -c udf_names.c udf_names.c:3:17: error: udf.h: No such file or directory udf_names.c:4:18: error: prop.h: No such file or directory udf_names.c:5:17: error: dpm.h: No such file or directory udf_names.c:6: warning: type defaults to int in declaration of DEFINE_PROFILE udf_names.c:6: warning: parameter names (without types) in function declaration udf_names.c:7: error: expected =, ,, ;, asm or __attribute__ before udf_data udf_names.c:10: error: udf_data undeclared here (not in a function) udf_names.c:10: error: UDF_Data undeclared here (not in a function) udf_names.c:11:21: error: version.h: No such file or directory udf_names.c: In function UDF_Inquire_Release: udf_names.c:14: error: RampantReleaseMajor undeclared (first use in this function) udf_names.c:14: error: (Each undeclared identifier is reported only once udf_names.c:14: error: for each function it appears in.) udf_names.c:15: error: RampantReleaseMinor undeclared (first use in this function) udf_names.c:16: error: RampantReleaseRevision undeclared (first use in this function) make[3]: *** [udf_names.o] Error 1 # Compiling heatfluxudf_linear.o because of heatfluxudf_linear.c udfconfig.h cc -D_lnamd64 -D_GNU_SOURCE -fpic -shared -ansi -Wall -O -DPTR_RESTRICT= -I/Applications/ansys_inc/v150/fluent/fluent15.0.0/`expr "\`pwd\`" : '.*/\(.*\)/[23].*'`/`basename "\`pwd\`"` -I/Applications/ansys_inc/v150/fluent/fluent15.0.0/src -I/Applications/ansys_inc/v150/fluent/fluent15.0.0/cortex/src -I/Applications/ansys_inc/v150/fluent/fluent15.0.0/client/src -I/Applications/ansys_inc/v150/fluent/fluent15.0.0/tgrid/src -I/Applications/ansys_inc/v150/fluent/fluent15.0.0/multiport/src -I/Applications/ansys_inc/v150/fluent/fluent15.0.0/multiport/mpi_wrapper/include -I/Applications/ansys_inc/v150/fluent/fluent15.0.0/multiport/mpi_wrapper/src -I. -c heatfluxudf_linear.c heatfluxudf_linear.c:1:16: error: udf.h: No such file or directory heatfluxudf_linear.c:2:17: error: prop.h: No such file or directory heatfluxudf_linear.c:3:16: error: dpm.h: No such file or directory heatfluxudf_linear.c:5: warning: return type defaults to int heatfluxudf_linear.c: In function DEFINE_PROFILE: heatfluxudf_linear.c:7: error: real undeclared (first use in this function) heatfluxudf_linear.c:7: error: (Each undeclared identifier is reported only once heatfluxudf_linear.c:7: error: for each function it appears in.) heatfluxudf_linear.c:7: error: expected ; before x heatfluxudf_linear.c:8: error: expected ; before y heatfluxudf_linear.c:9: error: face_t undeclared (first use in this function) heatfluxudf_linear.c:9: error: expected ; before f heatfluxudf_linear.c:10: warning: implicit declaration of function begin_f_loop heatfluxudf_linear.c:10: error: f undeclared (first use in this function) heatfluxudf_linear.c:11: error: expected ; before { token make[3]: *** [heatfluxudf_linear.o] Error 1 make[3]: Target `libudf.so' not remade because of errors. make[3]: Leaving directory `/home_nfs/USERS/PE_EX/vignaesh.subramaniam/Upload/Fluent/libudf/lnamd64/2ddp' make[2]: *** [lnamd64] Error 2 make[2]: Leaving directory `/home_nfs/USERS/PE_EX/vignaesh.subramaniam/Upload/Fluent/libudf/lnamd64/2ddp' make[1]: *** [default] Error 2 make[1]: Leaving directory `/home_nfs/USERS/PE_EX/vignaesh.subramaniam/Upload/Fluent/libudf/lnamd64/2ddp' |
April 7, 2015, 18:54 |
anonymous
Rep Power: 11 |
If your UDF is compiling in serial and not in parallel I would send a ticket into to the ansys help.
April 7, 2015, 18:57 |
Rep Power: 18 |
Does this UDF compile in serial and parallel on a desktop machine?
What commands are you using to compile in serial, and parallel? |
April 8, 2015, 03:41 |
saad
Yes i m working on desktop machines ( im the person who posted this by the way)
I use a Journal like : File read-case dens.cas read-dara dens.dat Solve dti 1000000 But the problem is why it can't find the udf.h |
April 8, 2015, 03:52 |
Rep Power: 18 |
Are you compiling the UDFs through the GUI? What operating system are you running? What are the UDFs?
April 8, 2015, 04:13 |
saad
Here are my udfs ImageUploadedByCFD Online Forum1428480758.746058.jpg ImageUploadedByCFD Online Forum1428480788.864344.jpg
April 8, 2015, 04:48 |
Rep Power: 18 |
April 8, 2015, 05:17 |
saad
I am using the same code. When i m in locale i compile my udf manually but when i m in the parallel mode i use the Journal ( i m working in Linux ) the thing in this story is that calculation s are getting even if my udf display some errors
November 6, 2015, 13:44 |
#9 |
xin
Rep Power: 12 |
Hi, I have the same errors as you do. Did you solve it finally?
how to check UDFs code errors? | gjm89 | Fluent UDF and Scheme Programming | 5 | December 10, 2014 17:57 |
interDyMFoam in parallel | idefix | OpenFOAM Running, Solving & CFD | 0 | May 21, 2013 02:34 |
Running UDFs in parallel | Emre Turkoz | CFX | 2 | February 1, 2011 09:10 |
problem using property udfs in parallel mode | EllenW | Fluent UDF and Scheme Programming | 5 | July 10, 2009 04:31 |
Help with parallel UDFs needed | Nico | FLUENT | 0 | June 6, 2006 08:40 |
