UDF for time dependent heat flux
Hello!
I am very new to ANSYS. I am modeling a simple conduction + convection model. Although the heat source in this is more like a PULSE. In a 300 msec cycle, a heat pulse of 10 msec long is sent at 50th msec. All the time except for the pulse duration is for cooling. I have written an UDF, that can be seen below (with my negligible knowledge of writing an UDF). When I try to interpret it, I am getting an errors: 1. line 35:parse error, 2. f_loop_last: undeclared variable. I am not able to understand the cause of these errors. I tried looking at other threads, but I still couldn't understand what's wrong. Can some one please have a look and give me some kind of feedback? I highly appreciate your time, thank you very much. Code: # include "udf.h" # include "unsteady.h" DEFINE_EXECUTE_AT_END (execute_loop) { face_t f; Thread *t; real c_time=0.0000; real q; c_time=CURRENT_TIME; if (c_time<0.05) { q=0; } if ((c_time>=0.05)&&(c_time<=0.06)) { q=10000; } if (c_time>0.06) { q=0; } DEFINE_PROFILE(HeatPulse, t, i) { begin_f_loop (f,t) F_PROFILE(f,t,i) = q; end_f_loop(f,t) } } |
Are you sure you're interpreting the code you've copied above? There are less than 35 lines of code (your first error mentions an error on line 35) and "f_loop_last" (your second error) is not found in your code.
Try compiling instead of interpreting UDFs (more stable) and the pulse can be applied within the DEFINE_PROFILE macro without using the second macro (CURRENT_TIME is available at each step the profile is applied to the boundary). |
Sorry about that, I did not copy the comments at the beginning of the code, which I had written for my benefit.
Thank you very much for your help. But, I figured out yesterday that DEFINE_PROFILE with CURRENT_TIME was all I needed. So I was able to interpret the UDF. Although now, I am trying to find a way to check if the pulse was applied or not. So its its more like a question of reading the data. Let's see what happens, once I figure out how to read if the pulse was applied at the instances I wanted. |
Rontgen can you please send your UDF which ran without error?
#include "udf.h" |
Thanks a lott Alaxender
