Defining CG MOTION
Hi all,
I am trying to model a fluid body. One wall of the fluid body will be fixed, while another wall at the other extreme will be subjected to linear and angular velocity in the x,y and z direction (I suppose this requires the 6dof solver). However when I try to run the simulation, there isn't any velocity values assigned to the 3 directions. I am thinking it may be because I did not define the CG in my code or on fluent properly. Have attached my code right here, would appreciate if anyone can advise me on this. Thank you! __________________________________________________ ________- #include "udf.h" #include "math.h" #include "dynamesh_tools.h" DEFINE_CG_MOTION(valve, dt, vel, omega, time, dtime) { /* reset velocities */ NV_S (vel, =, 0.0); NV_S (omega, =, 0.0); /* compute velocities formula */ vel[0]=0.0011; /* computing linear velocities */ vel[1]=0.001225; vel[2]=0.0042; omega[0]=-0.09774; omega[1]=0.317214; omega[2]=0.15184346; printf("\n"); printf("\n rotational_speed = %g \n",omega[2]); } |
hi
I am the student of fluid mechanics and now I am studying on fluid project. The subject of my project is about blade turbine that Oil radially impacts to the turbine blades by a nozzle, causing the turbine to spin. I have a problem in modeling of turbine that I don’t know how to obtain moment of inertia of blade and fluid and how to relate this challenge to the Cg motion until I can model this turbine in fluent software. Please help me Thank for your attention |
I had the same issue. Make sure that you have assigned UDF in dynamic mesh options to every boundary of the cell zone, including interior. In my case I have forgotten about interior.
