UDF Macro for Mass Diffusivity using Kinetic Theory
Like Tree2Likes
  • 1 Post By rewol
  • 1 Post By obscureed
Old   December 6, 2018, 08:08
Default UDF Macro for Mass Diffusivity using Kinetic Theory
Emerson
souza.emer is on a distinguished road
Hello everyone
I want to use the Kinetic Theory model for Mass Diffusivity and use its value, for each species, in a UDF to calculate the reaction rate. My question is, which macro should I use? Is it one of those two?
C_DIFF_L(c,t); Laminar species diffusivity
C_DIFF_EFF(c,t,i); Effective species diffusivity
If not, how can I call it?
Thanks for the attention.
souza.emer is offline   Reply With Quote
Old   December 6, 2018, 10:42
obscureed is on a distinguished road
Hi there,
The macros that you mention are for accessing values, not setting them. For defining, look at DEFINE_DIFFUSIVITY. If you want to include the effects of turbulence on diffusion (which, in a turbulent situation, you definitely do), you need to add this to the diffusivity of a User-Defined Scalar. (The manual's example makes this clear.) For a species, I *think* turbulence effects are added separately -- this is what the Theory Guide appears to say, but I don't remember checking in detail.
But then, there is a built-in version of kinetic theory for diffusivity, and this uses the molecular masses, species by species. (In fact, it seems to calculate it for each species-species pair, which does not seem possible in the UDF. Hmm.)
Good luck!
Ed
obscureed is offline   Reply With Quote
Old   December 6, 2018, 11:49
Emerson
Hello
Yeah, I know that Macros are used for accessing the values, that's why I'm in doubt because I'm not sure of how I could use the value of diffusivity calculated by the Kinect Theory when I set this previously at the materials menu in Fluent.
I do not want to use the macro to modify the current diffusivity coefficient calculated by Kinect Theory theory, I just want to use the value which Fluent calculates.
I think you thought that I wanted to modify it, which I do not want to, yet.
Do you know how I can do this? Or make any suggestions?
Best
Old   December 6, 2018, 13:12
Refik
rewol is on a distinguished road
You can use DEFINE_NET_REACTION_RATE macro to calculate reaction rates and inside the code you can utilize C_DIFF_L(c,t) or C_DIFF_EFF(c,t,i) to access mass diffusivities of the species.
souza.emer likes this.
rewol is offline   Reply With Quote
Old   December 6, 2018, 19:11
Hi Souza.Emer,
Yes, you are correct that I assumed you wanted to define the values. Sorry, this is a more frequent request than accessing values in UDF (because you can access the values in normal postprocessing if you want).
For accessing the built-in values, without any turbulent influence, C_DIFF_L is what you want. But check the manual for syntax -- C_DIFF_L(c,t) is not correct.
You can do this accessing inside several types of UDF -- rewol mentions one, though that is specific to the kinds of model that will accept it. DEFINE_ON_DEMAND is a general option: first look up a domain pointer, then find some cell or face zones, and loop through some faces or zones.
Good luck!
Ed
Old   May 28, 2019, 14:28
Weiqiang Liu
Weiqiang Liu is on a distinguished road
hello, can I ask a question under this thread?
I checked the syntax in manual and found the correct syntax is C_DIFF_L(c,t,i,j). I am wondering is the diffusion coefficient I am accessing with this macro is binary diffusion coefficient? what if I want to access mixture averaged diffusion coefficient or multi-component diffusion coefficient?
Weiqiang Liu is offline   Reply With Quote
Diffusivity UDF in Fluent max.kozak Fluent UDF and Scheme Programming 0 April 4, 2018 19:16
UDF for anisotropic diffusivity Zerzura Fluent UDF and Scheme Programming 2 December 20, 2015 09:37
the macro DEFINE_MASS_TRANSFER can't use as compile udf in ansys14.0 fangdian Fluent UDF and Scheme Programming 13 August 23, 2014 10:00
what does FLUID_THREAD_P(t) macro do in udf? borhan_sd@yahoo.com Fluent UDF and Scheme Programming 2 June 10, 2013 05:49
solid kinetic theory wan xiaotao Main CFD Forum 6 August 10, 1999 18:43
