Compile UDF for Fluent
I need to include Lorentz force equation as a source term in my model. how can i compile a UDF and use it in fluent ?
Use the DEFINE_SOURCE macro for specifying a custom source term (ensure the units are of the form generation rate per volume, e.g. kg/m^3/s for the continuity equation), there are a couple of examples in the UDF manual to get you started (ask back here if you get stuck). As for compiling UDFs, see the reply in your duplicate thread.
respected sir,
could suggest me what mistake i do in this code as given below ? #include "udf.h" #define mu 1.26*(10e-6) #define I 300 #define reff 0.008 #define r 0.005 /*-------------------------------------------------------- Momentum source term in x ----------------------------------------------------------*/ DEFINE_SOURCE(xmom_source,c,t,dS,eqn) { float x[ND_ND], source; face_t f; F_CENTROID (x,f,t); source =-((mu*I*I)/(4*3.14*3.14*reff*reff*r)) * (exp (-r*r / (2*reff*reff))) * (1-(exp (-r*r / (2*reff*reff)))) * pow((1-(x[1]/t),2) * (x[0]/r); dS[eqn] = 0; return source; } /*-------------------------------------------------------- Momentum source term in y ----------------------------------------------------------*/ DEFINE_SOURCE(ymom_source,c,t,dS,eqn) { float x[ND_ND], source; face_t f; F_CENTROID (x,f,t); source = -((mu*I*I)/(4*3.14*3.14*r*r)) * pow((1-(exp (-r*r / (2*reff*reff)))),2) * (1-(x[1]/t)); dS[eqn] = 0; return source; } /* HEAT INPUT CODE */ DEFINE_PROFILE(Gauss,t,i) { real x[ND_ND], c[ND_ND]; face_t f; real r; r = 0.0035; begin_f_loop(f, t) { F_CENTROID (x,f,t); F_PROFILE (f,t,i) = (3*(300*14*0.7) / (3.14*pow(r,2))) * exp (-3*(x[0]*x[0])/ pow(r,2)); } end_f_loop(f,t) } |
For starters, use a trailing dot for real numbers (otherwise the compiler will read them as integers), for example:
F_PROFILE (f,t,i) = (3.*(300.*14.*0.7) / (3.14*pow(r,2))) * exp (-3.*(x[0]*x[0])/ pow(r,2)); |
i have modified the format with trailing dot as suggested. the UDF is given below and it gives the error: Line 27: invalid type for binary expression: float / pointer to structure.
how can i rectify the error in the following udf ? /*------ HEAT FLUX -------- */ #include "udf.h" DEFINE_PROFILE(Gauss,t,i) { real x[ND_ND], c[ND_ND]; face_t f; real r; r = 0.005; begin_f_loop(f, t) { F_CENTROID (x,f,t); F_PROFILE (f,t,i) = (3.*(300.*14.*0.7/0.001) / (3.14*pow(r,2.))) * exp (-3.*(x[0]*x[0])/ pow(r,2.)); } end_f_loop(f,t) } /*--------- Lorentz Force ----------*/ /*-------- x momentum source ------*/ #DEFINE mu 0.00000126; #DEFINE I 300.; #DEFINE reff 0.006; #DEFINE r 0.005; DEFINE_SOURCE(xmom,c,t,dS,eqn) { real x[ND_ND]; real mu, I, reff, r, source; C_CENTROID(x,c,t); source = -((mu*I*I)/(4.*3.14*3.14*reff*reff*r)) * (exp (-r*r / (2.*reff*reff))) * (1.-(exp (-r*r / (2.*reff*reff)))) * pow((1.-(x[1]/t),2.) * (x[0]/r)); dS[eqn]=0; return source; } /* ----------- y momentum source ------------*/ DEFINE_SOURCE(ymom,c,t,dS,eqn) { real x[ND_ND]; real source; C_CENTROID(x,c,t); source = -((mu*I*I)/(4.*3.14*3.14*r*r*c)) * pow((1.-(exp (-r*r / (2.*reff*reff)))),2.) * (1.-(x[1]/t)); dS[eqn]=0; return source; } |
One of your problems is here:
#DEFINE mu 0.00000126; Code:
real 0.00000126;, 300.;, 0.006;, 0.005;, source; Code:
#DEFINE I 300. Option 2: don't use #DEFINE: Code:
real mu=0.00000126, I=300, ... |
