any macros to get this?
Like Tree2Likes
  • 1 Post By `e`
  • 1 Post By `e`
Old   February 10, 2016, 22:02
Default any macros to get this?
hwet is on a distinguished road
Good day
I want a udf for the discrete phase to be activated only when the particle passes through a cell with a specific property.
For example, the DEFINE_DPM_BC is activated only when the particle hits a wall. But, here I am trying to activate the UDF while the particle is travelling away from the walls and only when it passes through a cell with a certain property.
To be specific the cells representing a different eulerian phase which is moving constantly as well. So the UDF is called only when the particle enters such a cell.
Is this even possible to achieve? Am i looking at a DEFINE_ON_DEMAND macro? Usually the DPM macros are called at everytime step but this wont be very efficient in my case where the cell occupied by the eulerian phase is only a small fraction of the total number of cells.
hwet is offline   Reply With Quote
Old   February 11, 2016, 05:14
`e`
`e` is on a distinguished road
The DEFINE_ON_DEMAND macro is only executed when you manually enable it (unless you're using scripts). The DEFINE_DPM_SCALAR_UPDATE macro is called each time a particle position is updated. With conditional statements, you can restrict when code is executed and this method is generally quick (I can't think of a more elegant solution). For an arbitrary example, a particle travelling away from a wall (on the XZ plane) within a cell of a high velocity:
DEFINE_DPM_SCALAR_UPDATE(certain_particles,c,t,initialise,p)
	if (P_VEL(p)[1] > 0. && C_U(c, t) > 1.)
		// a code block
If, however, you wanted to modify the force acting on the particle in certain regions of your domain then you could use the DEFINE_DPM_BODY_FORCE macro.
DEFINE_DPM_BODY_FORCE(certain_particles_force,p,i)
	cell_t c;
	Thread *t;
	c = P_CELL(p);
	t = P_CELL_THREAD(p);
		// a code block
hwet likes this.
`e` is offline   Reply With Quote
Old   February 11, 2016, 19:23
Aren't these already passed in the macro?
DEFINE_DPM_SCALAR_UPDATE(certain_particles,''c'',''t'',initialise,p)
Why would we need this then?.
cell_t c;
Thread *t;
c = P_CELL(p);
Old   February 11, 2016, 23:09
`e`
Woops, that's correct: you won't need to find the cell number and thread for the DEFINE_DPM_SCALAR_UPDATE macro (already provided) but it's required for DEFINE_DPM_BODY_FORCE (only provides the particle and direction index).
hwet likes this.
Some guidance is needed about UDF macros highhopes Fluent UDF and Scheme Programming 2 July 3, 2012 09:41
Tecplot360 - Macros calling Macros? eRzBeNgEl CFX 1 April 15, 2011 06:32
help with macros F_ID and C_ID Jack Martinez FLUENT 0 August 19, 2007 08:27
What are UDF macros C_T_S , C_T_AP,...???? Asghari FLUENT 0 January 28, 2007 10:54
Orientation of Face Variable Macros hirokata FLUENT 0 February 17, 2006 00:12
