Getting error while executing command to get image of velocity contour
2 Attachment(s)
I am working on this kind of geometry for udf to get rpm.After setting all the thing i moved to the "calculation activo-> execute command -> create -> define two command as image attachedAttachment 45133
Command1 :- /display/set/contoured/filled-contour/y /display/contour/velocity-magnitude.. Command 2 :- /display/hard-copy"velocity-%t.tif" But i m getting error as attachedAttachment 45134 Tell me if command text is wrong and guide for solution. Also tell how to make animation from that images |
Your text and your picture don't show the same text.
In the picture, you typed "hard copy", in the text you typed "hard-copy". |
What if i m getting negative cell volume detected in dynamic mesh?? Guide for a solution
