September 18, 2014, 09:04 |
Loading library via scheme command
Rep Power: 14 |
Hello
It might seem a silly question. I wish to load some user defined udf library and to make this procedure automatic by scheme command, saved in a .scm file. 1) Within the Fluent interface, the library loading is done normally by: Define>User-defined>function>manage. 2) In the fluent environment, the following scheme command do the loading of the library: (ti-open-udf-library)load libudf 3)However, I wish to save this procedure into a .scm file, to be opened via file>read>scheme When executing the .scm file, fluent is stoping after the first command (ti-open-udf-library) and request to give the answer to load/unload/compile. This is not really what i was looking for, as the aim was not to have to interact. My question is: why, while reading the .scm file, fluent is stopping at the first scheme command (while it does not if I am writing it directly on the fluent window, and access the load command by itself) Does anyone knows how to overcome this issue? Thanks for any help |
March 31, 2017, 04:01 |
Rosario Arnau
Rep Power: 9 |
Hi!
I have almost the same problem. How do you solve that? I've been thinking to use DEFINE_EXECUTE_ON_LOADING or EXECUTE_ON_LOADING but I don't know the difference Thanks in advance |
March 31, 2017, 04:23 |
Rep Power: 26 |
For me, the following works:
(open-udf-library "libudf") |
March 31, 2017, 06:50 |
Rosario Arnau
Rep Power: 9 |
library, scheme |
ERROR: unable to find library | HJH | CFX | 6 | February 26, 2019 06:52 |
Implementation of QUICK scheme | Romuald Skoda | Main CFD Forum | 11 | November 6, 2017 21:20 |
UDF Compilation Error - Loading Library - COMMON Problem! Help! | robtheslob | Fluent UDF and Scheme Programming | 8 | July 24, 2015 00:53 |
8x icoFoam speed up with Cufflink CUDA solver library | kmooney | OpenFOAM Running, Solving & CFD | 42 | November 6, 2012 11:37 |
SCHEME command to write XY plot to file? | Angelo Sozzi | FLUENT | 1 | July 22, 2004 16:54 |
