DPM drag UDF
Old   June 1, 2009, 15:25
Default DPM drag UDF
Hanz is on a distinguished road
I'm currently writing my first UDF but am a bit stuck
I need to call the properties of the gas in which the inert particle resides in order to write the equation for drag, such as temperature, Cp etc. I'm currently using the Macro DEFINE_DPM_DRAG(particle_drag_force, Re, p).
Any help would be great.
Hanz
Hanz is offline   Reply With Quote
Old   June 28, 2016, 17:50
Leo
mail.leonardo is on a distinguished road
Hello Hanz,
I hope you have solved yout problem meantime
I am actually about start working on writing an UDF to modify the drag law in the DPM framwork. In particular I should use the Syamlal O'Brian (parametric with Umf and Epsilon on fluidization onset from the experiment) drag law as I did for the TFM. I know that there is an old tutorial for the TFM multiphase application (made when ansysis still did not have this feature already implemented inside) but now I am struggling to figure how to apply the same procedure into the DPM scheme. Do you have any idea at this regard?
Thanks a lot for your attention and support,
Leonardo
mail.leonardo is offline   Reply With Quote
DPM UDF particle position using the macro P_POS(p)[i] dm2747 FLUENT 0 April 17, 2009 02:29
DPM with UDF - Step-by-Step Procedure???? Prashanth FLUENT 3 April 3, 2009 18:45
UDF for Drag Srivatsan FLUENT 1 January 2, 2007 08:13
DPM - UDF for fluctuating bubble size Jaroslav Kotara FLUENT 1 April 19, 2006 10:02
DPM drag force UDF hedonists FLUENT 0 March 12, 2003 22:10
