errors while compiling udf
Old   May 8, 2019, 05:50
Unhappy errors while compiling udf
Shakib
shakib is on a distinguished road
Hi every one
I have several errors while compiling udf
I work with Visual Studio 2017 and ansys fluent 17 on Windows 10;
first: when I build libudf, in the win64\3ddp folder and after doing nmake with cross x64 tools command prompt, it cant make libudf.dll so while loading udf there will be an error as shown below in the attached picture.
Therefore when I copy it my self in the folder mentioned, an error named error code: 126 will appear.
now I'm confused.
Thank you in advance.
shakib is offline   Reply With Quote
Old   May 9, 2019, 00:26
Alexander
AlexanderZ will become famous soon enoughAlexanderZ will become famous soon enough
https://www.cfd-online.com/Wiki/Flue...UDF.29_Related
best regards
AlexanderZ is offline   Reply With Quote
Old   May 11, 2019, 00:56
Thumbs up
Shakib
Originally Posted by AlexanderZ View Post
Thanks alot it was very helpfull.
My problem was solved with the below procedure:
libudf.dll error in my case was Because the lack of "register environment variable" so it was solved by using "x64-x86 cross tools command prompt for vs2017" then changing the address to "C:\Program Files (x86)\Microsoft Visual Studio\2017\Enterprise\VC\Auxiliary\Build" then type:vcvars64.bat and enter so it will change to x64, then you have to type the destination folder that your .cas & .dat & udf exists (in the other words the folder that contains your library like libudf) then making "nmake" like this: C:\users\user_name\work_dir\libudf\win64\3ddp>nmak e. now you can load your libudf and you can see the problem is solved
udf compile
LINK errors compiling udf marco91 Fluent UDF and Scheme Programming 0 December 5, 2018 06:13
UDF - compiling errors Tscar FLUENT 1 March 21, 2018 22:24
How to write k and epsilon before the abnormal end xiuying OpenFOAM Running, Solving & CFD 8 August 27, 2013 15:33
Errors when Compiling UDF: error C2040/error C2099 Julian K. FLUENT 1 December 21, 2008 00:23
Could anybody help me see this error and give help liugx212 OpenFOAM Running, Solving & CFD 3 January 4, 2006 18:07
