DPM UDF for switching law
Old   September 14, 2016, 09:15
Default DPM UDF for switching law
Amila C Kahawalage
amilachandra is on a distinguished road
Hi, All
I want to write Fluent UDF for switching customs law in DPM model as shown bellow
#include "udf.h"
#include "dpm.h"
DEFINE_DPM_SWITCH (Cal_SwitchLaw,p,coupled)
Material *m=P_MATERIAL(p);
real fv=DPM_VOLATILE_FRACTION(p);
if (P_T(p)<DPM_VAPOR_TEMP(p,m))
P_CURRENT_LAW(p)=DPM_LAW_INITIAL_INERT_HEATING;
else
if (P_MASS(p)>(P_INIT_MASS(p)*(1-fv)))
P_CURRENT_LAW(p)=DPM_LAW_USER_1;
else
P_CURRENT_LAW(p)=DPM_LAW_FINAL_INERT_HEATING;
I am using ANSYS Fluent 16.2 version (64 bit).
I use following software with Fluent to run and compiled the udf
MS visual studio express edition 2010 with SP1 and MS windows SDK for windows 7.1 and .net framework 4
I compiled the UDF without errors. I can not run the programme. It shows following error message
Updating solution at time level N... done.
Injecting 48 particle parcels with mass 0.0004 at t = 0
Advancing DPM injections ...
Error: received a fatal signal (Segmentation fault).
Error Object: #f
Can any one help me ………..?
amilachandra is offline   Reply With Quote
Old   September 15, 2016, 03:43
Amila C Kahawalage
Hi, does anyone know the reason ?
UDF for DPM Law Switch Leepox Fluent UDF and Scheme Programming 0 August 26, 2013 05:36
Convert VOF droplet to DPM particle via UDF TedBrogan Fluent UDF and Scheme Programming 1 May 1, 2012 11:01
Hooking a DPM Particle Heat and Mass Transfer UDF to FLUENT subhankar_bhandari Fluent UDF and Scheme Programming 0 August 19, 2010 03:09
DPM - UDF for fluctuating bubble size Jaroslav Kotara FLUENT 1 April 19, 2006 09:02
UDF DPM Unsteady Lourival FLUENT 5 February 24, 2006 07:36
