is it possible to compile/interpret UDF outside fluent, just like simple C program. |
October 6, 2016, 19:31 |
I wrote UDF, i know how to compile in ANSYS fluent, or workbench.
But then again it's just a C program, with header file in it! so how can I compile outside fluent like C program, using gcc and output file will be the assembly code which fluent shows, when the option is ticked. I thought, if all header files in UDF header file are assembled in single folder, then it's possible, maybe, I'm not sure though. |
October 7, 2016, 03:46 |
Rep Power: 26 |
I am sure it is possible, because Fluent also does it.
But why do you want this? Are you only asking this question to get insight on what Fluent does when you click 'build', or is there a specific problem that you think you can solve when you can compile your own UDF codes? |
How to solve UDF compilation problems in Fluent. | pakk | Fluent UDF and Scheme Programming | 16 | September 10, 2018 02:48 |
Fluent 6.3.26 on Linux does not compile an UDF | Entwistle | Fluent UDF and Scheme Programming | 1 | March 4, 2014 14:49 |
fluent udf problem: write specific data for every iteration in a file. | nnvoro | Fluent UDF and Scheme Programming | 1 | May 27, 2013 15:26 |
FLUENT UDF Simple error. | startup0820 | Fluent UDF and Scheme Programming | 0 | August 14, 2012 03:54 |
Compiling UDF in Fluent 12 | jsm | FLUENT | 1 | July 22, 2009 07:40 |
