Error when initializing the simulation using UDF
Hi everyone,
Fluent show an error when I initialize the simulation. "Error: received a fatal signal (Segmentation fault)." "Error Object: #f" I am using UDF for temperature dependent property of water. Can anyone tell me how to remove this error. The UDF I am using for temperature dependent density is as follow: #include "udf.h" DEFINE_PROPERTY(water_density, cell, thread) { real den; real t = C_T(cell,thread); den=1000*(1-(((t+15.9414)*pow(t-276.9863,2)) / (508929.2*(t-204.87037)))); return den; } Thank you |
The UDF wants to read temperature, but that is not calculated yet, because you are initializing.
The solution that requires no programming: first initialize, then load the UDF. |
