How to access only one phase in multiphase model by UDF |
September 23, 2009, 07:57 |
Soeren Werner
Rep Power: 17 |
Hello guys,
I am trying to write an UDF to write data (cell volume, spec diss rate) only for one phase in multiphase (vof) model. However, either I get all cells or a segmentation violation error. I tried different methods to access only primary_phase by threads or domains, but I do not have any success. Could you help me please... For checking, used a quader with 8000 cells, patched to water in 4000 cells. I did and didnt run some iterations, nothing helps... This UDF writes cell volume of all cells, not only primary phase If I switch C_VOLUME to C_D for spec diss rate, a seg viol error aoccurs. Code:
#include "udf.h" DEFINE_ON_DEMAND(write_data) { cell_t c; int ID = 2; /* Zone ID for wall-1 zone from Boundary Conditions panel */ Domain *mixture_domain = Get_Domain(1); Domain *subdomain = DOMAIN_SUB_DOMAIN(mixture_domain,0); Thread *thread = Lookup_Thread(subdomain, ID); FILE *output=fopen ("epsilon.out","w"); begin_c_loop(c, thread) { fprintf(output,"\nvof=%e", C_VOLUME(c,thread)); } end_c_loop(c, thread) fclose(output); } This UDF writes C_VOF for all cells, not only primary phase eventhough C_VOF(c,pt[1]) Code:
#include "udf.h" DEFINE_ON_DEMAND(print_vof) { Domain *mix_domain = Get_Domain(1); Thread *mix_thread; Thread **pt; mp_thread_loop_c(mix_thread, mix_domain, pt) { cell_t c; begin_c_loop(c, pt[1]) Message("cell volume fraction = %f\n",C_VOF(c,pt[1])); end_c_loop(c, pt[1]) } } Eventhough if(C_VOF(cell,subthread) = 1) Code:
#include "udf.h" DEFINE_ON_DEMAND(print_id) { Domain *mixture_domain = Get_Domain(1); Domain *s_d = DOMAIN_SUB_DOMAIN(mixture_domain,0); /*subdomain pointer, locally defined*/ Thread *mixture_thread; cell_t cell; int p_d; /* loop counter for phase_domain_index, locally defined*/ int p_d_id; /* mix_domain is available*/ FILE *output=fopen ("epsilon.out","w"); fprintf (output, "energy dissipation rate distriubtion\n"); fprintf (output, "epsilon,volume\n"); int phase_domain_index=0; sub_domain_loop(s_d, mixture_domain, phase_domain_index) { /* loop over all cell threads in the primary phase domain */ thread_loop_c(mixture_thread,s_d) { /*Thread *st = THREAD_SUB_THREAD(cell_thread, 0);*/ /* loop over all cells in primary phase cell threads */ begin_c_loop(cell,mixture_thread) { /*if(C_VOF(cell,mixture_thread) = 1)*/ Message("\nDone... %g", C_VOF(cell,mixture_thread)); fprintf(output,"\nDone..."); } end_c_loop(cell,mixture_thread) } } fclose (output); } Examplers for parallelizing are here: http://www.fluentusers.com/fluent/do...df/node231.htm I do not know how I can to this when using a loop over domains or threads, since the size of the array needs to be send from nodes to host... If I check the udf, it seems very clear to me: I define a domain, then a subdomain, then I define a thread by using subdomain for lookup... That means, in thread it is supposed to point to thread in subdomian, or better to thread in domain with phase index 0... However, C_VOLUME can be written, but C_D or C_VOF causes a seg viol error... Actually, the task seems very easy to me. Write cell values from cells which are associated with primary phase. I have tried different methods to access one phase only. However, I am at one's wit' end... Any help is much appreaciated. Thanks, Sören Last edited by wersoe; September 23, 2009 at 08:22. |
January 4, 2017, 07:11 |
#2 | |
Przemek
Rep Power: 15 |
Try this code: Code:
DEFINE_INIT(my_init_function, domain) { Thread *t; Thread **pt; Thread **st; cell_t c; Domain *pDomain = DOMAIN_SUB_DOMAIN(domain,P_PHASE); Domain *sDomain = DOMAIN_SUB_DOMAIN(domain,S_PHASE); real xc[ND_ND], y, x; mp_thread_loop_c (t,domain,pt) if (FLUID_THREAD_P(t)) { Thread *tp = pt[P_PHASE]; begin_c_loop (c,t) { C_CENTROID(xc,c,t); x=xc[0]; if ( x > 0.02) C_VOF(c,tp) = 0; else C_VOF(c,tp) = 1; } end_c_loop (c,t) } mp_thread_loop_c (t,domain,st) if (FLUID_THREAD_P(t)) { Thread *sp = st[S_PHASE]; begin_c_loop (c,t) { C_CENTROID(xc,c,t); x=xc[0]; if ( x > 0.02 ) C_VOF(c,sp) = 1; else C_VOF(c,sp) = 0; } end_c_loop (c,t) } }
best regards pblasiak |
Modified k-e turbulence model UDF | Travis | Fluent UDF and Scheme Programming | 7 | November 11, 2018 20:21 |
Discrete phase or two phase model in Fluent? | andrea panizza | FLUENT | 14 | September 6, 2015 16:18 |
Superlinear speedup in OpenFOAM 13 | msrinath80 | OpenFOAM Running, Solving & CFD | 18 | March 3, 2015 05:36 |
UDF problem in multiphase model | Amir Khodabandeh | FLUENT | 1 | March 13, 2009 08:43 |
air and water vapour mixture - multiphase model | Saba | FLUENT | 0 | February 10, 2009 12:05 |
