define_wall_functions density and dynamic viscosity
Old   March 2, 2017, 08:16
Default define_wall_functions density and dynamic viscosity
G Ionut
Ionut G is on a distinguished road
Hi all,
I want to extract the dynamic viscosity for each cell in an udf DEFINE_WALL_FUNCTIONS.
Is C_MU_L(c,t) the dynamic viscosity? If not, how can I extract it from fluent?
Here is the code I use:
#include "udf.h"
#include "mem.h"
#define CMU 0.09
#define KARMAN 0.4187
#define E 9.793
#define MU 1.1e-3
DEFINE_WALL_FUNCTIONS(std_wf, f, t, c0, t0, wf_ret, yPlus, Emod)
real k, dist, y_plus;
real wf_value;
begin_c_loop(c0, t0)
rho = C_R(c0,t0);
mu = C_MU_L(c0,t0);
k = C_K(c0,t0);
dist = (yPlus*MU)/(DENSITY*pow(CMU,0.25)*pow(k,0.5));
y_plus = (DENSITY*pow(CMU,(1./4.))*pow(k,(1./2.))*dist)/MU;
end_c_loop(c0, t0)
switch (wf_ret)
case UPLUS_LAM:
wf_value = y_plus;
break;
case UPLUS_TRB:
wf_value = log(E*y_plus)/KARMAN;
break;
case DUPLUS_LAM:
wf_value = 1.0;
break;
case DUPLUS_TRB:
wf_value = 1./(KARMAN*y_plus);
break;
case D2UPLUS_TRB:
wf_value = -1./(KARMAN*y_plus*y_plus);
break;
default:
printf("Wall function return value unavailable\n");
return wf_value;
Any help will be appreciated, thank you!
Ionut G is offline   Reply With Quote
Old   March 2, 2017, 08:48
Kevin
KevinZ09 is on a distinguished road
Yes, C_MU_L(c,t) is the dynamic viscosity macro.
KevinZ09 is offline   Reply With Quote
Old   March 2, 2017, 09:39
G Ionut
Hi Kevin, thank you very much!
Old   March 15, 2017, 10:10
Default C_UDMI in define_wall_functions
G Ionut
I want to write in a variable the distance from the wall to the first cell using C_UDMI but i receive the following error:
iter continuity x-velocity y-velocity z-velocity k epsilon time/iter
Node 0: Process 88256: Received signal SIGSEGV.
Node 1: Process 87820: Received signal SIGSEGV.
Node 2: Process 88216: Received signal SIGSEGV.
Node 3: Process 88212: Received signal SIGSEGV.
Node 4: Process 88284: Received signal SIGSEGV.
Node 5: Process 88236: Received signal SIGSEGV.
Node 6: Process 87872: Received signal SIGSEGV.
Node 7: Process 87804: Received signal SIGSEGV.
Node 8: Process 88268: Received signal SIGSEGV.
Node 9: Process 87880: Received signal SIGSEGV.
Node 10: Process 88280: Received signal SIGSEGV.
Node 11: Process 87812: Received signal SIGSEGV.
Node 12: Process 88248: Received signal SIGSEGV.
Node 13: Process 88264: Received signal SIGSEGV.
Node 14: Process 88004: Received signal SIGSEGV.
Node 15: Process 86712: Received signal SIGSEGV.
MPI Application rank 0 exited before MPI_Finalize() with status 2
The fl process could not be started.
What I did wrong?
In the Number of User-Defined Memory Locations, I set 1.
The code is compiled using MS Visual Studio, I do not get errors when I compile the code.
I attached the C code.
Thanks in advance for help.
Ansys CFX problem: unexpected very high temperatures in premix laminar combustion faizan_habib7 CFX 4 February 1, 2016 17:00
How to find density without having dynamic viscosity? ooo OpenFOAM Running, Solving & CFD 6 January 28, 2014 12:46
Dynamic Viscosity at transportproperties dictionary NickolasPl Main CFD Forum 0 June 2, 2011 14:06
User-defined turbulent viscosity - kinematic or dynamic? tstorm Main CFD Forum 4 January 29, 2010 11:08
User-defined turbulent viscosity - kinematic or dynamic? tstorm FLUENT 0 August 13, 2009 16:49
