particle temperature stay low after employing UDF
Hello everyone!
i have employed the UDF about coal devolatilization model with DEFINE_DPM_LAWS and DEFINE_DPM_SOURCE. All parameters in my UDF have been printed out and seem to be okay except the coal particle temperature.The coal particle temperature stays about 420K, and did not get burned finnaly. I am confused about it, any suggestions would be welocomed. best wishes zjuxjk |
If you want us to help you see what is wrong with your UDF, you have to share the UDF.
#include "dpm.h" #include "dpm_laws.h" #include "dpm_types.h" #include "math.h" #include "sg_udms.h" #include "mem.h" #include "stdio.h" DEFINE_DPM_LAW(Devolatilization_rate,p,ci) { real dtemp; real temp1,temp2; real e1,k1,v1,e2,k2,v2; real dt; real volate_yield1, volate_yield2; real volate_rate1,volate_rate2; cell_t c= P_CELL(p); Thread *t= P_CELL_THREAD(p); real flow_time = CURRENT_TIME; if (P_TIME(p) < 0.003) { P_USER_REAL(p,3)=0.0; P_USER_REAL(p,4)=0.0; P_USER_REAL(p,5)=303; } else { temp1=P_USER_REAL(p,5); temp2=P_T(p); dt = P_DT(p); /*颗粒时间步长*/ dtemp= (temp2-temp1)/dt; printf("dtemp=%f\n") /*记录上一个时刻温度,并计算出瞬时升温速率*/ volate_yield1 =P_USER_REAL(p,3); volate_yield2 =P_USER_REAL(p,4); if (dtemp > 0.0) { e1=14543250000.0; e2=342553.3258955158*pow(dtemp,0.045354296); k2=7.33134539849e-32*pow(e2,6.85504718)*pow(dtemp,1.0); k1=395093626.7*pow(dtemp,0.367176979442845); v1=0.11602141*pow(dtemp,0.0313245); v2=0.385354371*pow(dtemp,-0.017575075); } else { e1=1435000.0; e2=3543512.3258955158*pow(100000.0,0.0453296); k2=7.33419849e-32*pow(e2,6.85504718)*pow(100000.0,1.0); k1=3950453626.7*pow(100000.0,0.345369735845); v1=0.11602141*pow(100000.0,0.4313245); v2=0.3849071*pow(100000.0,-0.3575075); } volate_rate1=(v1-volate_yield1 )*k1*exp(-e1/8.314/temp2); volate_rate2=(v2-volate_yield2 )*k2*exp(-e2/8.314/temp2); volate_yield1 = volate_yield1 + volate_rate1*dt ; volate_yield2 = volate_yield2 + volate_rate2*dt ; P_MASS(p)=P_INIT_MASS(p)*(0.974-0.848*(volate_yield1+volate_yield2)); P_USER_REAL(p,0)=volate_yield1; P_USER_REAL(p,1)=volate_yield2; P_USER_REAL(p,2)=temp2; C_UDMI(c,t,0)=P_T(p); } } DEFINE_DPM_SOURCE(dpm_source,c,t,S,strength,p) { real mvf_dot; mvf_dot=(P_MASS0(p)-P_MASS(p))*strength; if((P_T(p) > 400.0) && (P_MASS(p)>0.534536*P_INIT_MASS(p))) { S->species[0] += mvf_dot; S->energy += mvf_dot*15354000.0; C_UDMI(c,t,1)= mvf_dot; } } DEFINE_DPM_SCALAR_UPDATE(dpm_scalar,c,t,initialize ,p) { if (P_TIME(p) < 0.003) { P_USER_REAL(p,3)=0.0; P_USER_REAL(p,4)=0.0; P_USER_REAL(p,5)=303; } else { P_USER_REAL(p,3)=P_USER_REAL(p,0); P_USER_REAL(p,4)=P_USER_REAL(p,1); P_USER_REAL(p,5)=P_USER_REAL(p,2); } } this is my UDF code, thanks for your suggestions! |
