HELP: Solver not changing to desired outlet - UDF
Hi guys,
I am using fluent for my final year project and I'm having trouble with my UDF for specifying multiple threads. I am doing a transient boundary condition problem on a intake manifold for my university's FSAE team. The data that I have for the engine is a series of pressure curves for the inlet of intake runners. I have already simplified the data into piecewise functions whereby during the intake phase, the pressure is a function of [31400*sin(2028.65*t) - 101325] and it is set to 101325 kpa other times. I've done 4 sets of piecewise functions for each cylinder (although in the code theres only for 3 intake runners for now) The piecewise function is for 2 full engine cycles at 12000 RPM. I've attached my UDF code for your reference. I'm using DES #include "udf.h" DEFINE_ON_DEMAND(domian_id) { Domain *domain; domain = Get_Domain(1); } /************************************************** *************************************** CYLINDER 1 ************************************************** ***************************************/ DEFINE_ADJUST(centroids, domain) { int ID1 = 7; Thread *thread1 = Lookup_Thread(domain, ID1); } DEFINE_PROFILE(pressure_cyl1, thread1, p1) { real y[ND_ND]; face_t f; real t = CURRENT_TIME; real pressure1; if ((t>=0) && (t<0.00394444)) { pressure1=31400*sin(2028.65*t) - 101325; } if ((t>=0.00394444) && (t<0.01)) { pressure1=101325; } if ((t>=0.01) && (t<0.01394444)) { pressure1=31400*sin(2028.65*t) - 101325; } if ((t>=0.01394444) && (t<0.0275)) { pressure1=101325; } begin_f_loop(f, thread1); { F_CENTROID(y,f,thread1); t = y[1]; F_PROFILE(f, thread1, p1) = pressure1; } end_f_loop(f, thread1) } /************************************************** *************************************** CYLINDER 4 ************************************************** ***************************************/ DEFINE_ADJUST(centroids, domain) { int ID4 = 10; Thread *thread4 = Lookup_Thread(domain, ID4); } DEFINE_PROFILE(pressure_cyl4, thread4, p4) { real y[ND_ND]; face_t h; real t = CURRENT_TIME; real pressure4; if ((t>=0) && (t<0.005)) { pressure4=101325; } if ((t>=0.005) && (t<0.00894444)); { pressure4=31400*sin(2028.65*t) - 101325; } if ((t>=0.00894444) && (t<0.015)); { pressure4=101325; } if ((t>=0.015) && (t<0.01894444)); { pressure4=31400*sin(2028.65*t) - 101325; } if ((t>=0.01894444) && (t<0.025)); { pressure4=101325; } begin_f_loop(h, thread4) { F_CENTROID(y,h,thread4); t = y[1]; F_PROFILE(h, thread4, p4) = pressure4; } end_f_loop(h, thread4) } /************************************************** *************************************** CYLINDER 3 ************************************************** ***************************************/ DEFINE_ADJUST(centroids, domain) { int ID3 = 9; Thread *thread3 = Lookup_Thread(domain, ID3); } DEFINE_PROFILE(pressure_cyl3, thread3, p3) { real y[ND_ND]; face_t l; real t = CURRENT_TIME; real pressure3; if ((t>=0) && (t<0.0075)) { pressure3=101325; } if ((t>=0.0075) && (t<0.01144444)); { pressure3=31400*sin(2028.65*t) - 101325; } if ((t>=0.01144444) && (t<0.0175)); { pressure3=101325; } if ((t>=0.0175) && (t<0.02144444)); { pressure3=31400*sin(2028.65*t) - 101325; } if ((t>=0.02144444) && (t<0.0275)); { pressure3=101325; } begin_f_loop(l, thread3) { F_CENTROID(y,l,thread3); t = y[1]; F_PROFILE(l, thread3, p3) = pressure3; } end_f_loop(l, thread3) } Here is the problem: The UDF code can be interpreted without issues. But when I run the code, only the first intake runner has flow through it. I need the flow through all 4 runners varying with time. And from the solution animation it seems that all the pressure variation takes place in the first intake runner only. Here's what I've done: -using pressure outlet BC -set the UDM to 1 -used Lookup_Thread to specify thread pointer to specific outlets (the thread ID was obtained from the BC menu) - used 'real y[ND_ND]' since all the surface normal of the outlet is along the y axis (in the negative direction btw). -Placed all of the profiles in a single UDF -Restart fluent and reset the setup tab in workbench before every run. -using single processor -Inlet is set to constant inlet pressure BC I'm using DES for the solver model. Not sure if this might be important. If switching models would make a difference then please let me know. I've read through the Fluent UDF manual, tutorial guide, and gone through this forum a few times but I've yet to find anything that works. Any help at this moment will be greatly appreciated. This is my first time using Ansys Fluent and coding in C. So please go easy on me. Thank you in advance for your help. Regards, Kuna |
If you say 'real y[ND_ND]' to the interpreter, all it knows is that 'y' is a vector with real components. The interpreter has no idea which values you want to be there, until you tell the interpreter this. You never tell this to the interpreter. And later on, you ask the interpreter to give you y[1]. This is the second component (counting starts at 0) of this unknown vector. The interpreter will give you the value that happens to be in memory (or an error). Luckily for you, you never use the value: you assign it to 't', and never use 't' anymore. Luckily for you, the solution is easy: just remove the lines with y. You don't need them. Quote:
