UDF - Write data into file at the end of every time-step
Hello everyone,
I need to write a UDF to be executed with a transient simulation. I have specified the number of iterations to be carried out per time-step. I need to make a UDF that will write some data into a file at the end of each time-step. I don't want to see this at every iteration per time-step. Say, I specify 20 iterations per time-step. Then I want to have the data written at the end of 20th iteration or at the point where convergence is achieved for a time-step. Could someone tell me how can this be achieved? Thanks in advance! |
The EXECUTE_AT_END macro is executed at the end of each time step of a transient model...so if you write into your file inside this macro it will contain only the values at the end of each time step.
unfortunately, that did not work out. It is still printing values at every iteration per time-step. Could someone help me out on this? |
In static analys it is called at the end of iteration Sent from my Lenovo K50-t5 using CFD Online Forum mobile app |
Hi Boh and qorka,
Thanks for the reply. So that means it has to do something with my code. I wrote a UDF to calculate the point of slowest blending in a mixing tank based on mass fraction of species. I tried running it on a Linux system with one node (16 cores) but I did not make it compatible for parallel processing. Am getting weird results. Have to go back and check where I made the mistake. |
