Received a fatal signal (Segmentation fault) with UDF
Dear all,
Here is a error when iterates with UDF to solve extra transport equations of UDS. The error is Quote:
Thanks in advance. Shan |
DEFINE_UDS_FLUX(mfFlux,f,t,i) I still wanna know why with the DEFINE_UDS_FLUX it doesn't work. Could anybody help me? Thanks for any reply. Shan |
Received a fatal Signal ( Segmentation fault )
Hi everyone !
I hope you are fine. I am using UDF in VOF model in ANSYS FLUENT, although, my VOF model without UDF is running fine. The UDF is written by my friend used it successfully. He has graduated last year after getting the results from same UDF. The UDF was working well on his server. He was using Fluent 6.3 on Linux system. When I am using same case, date and UDF on my laptop the case is not running, although UDF compilation is very fine. I also check it on Linux system too. During or after initialization, Error occurred segmentation fault error. It is very strange that same case and UDF is not working on his office now. Main error occurred when I am hooking ADJUST and EXECUTE-AT-END UDFs. May be there is some problem of writing/calling style is different in Windows and Linux system with 32bit and 64bit. ( this is just my opinion). I hope you can understand the situation and have a try to fix the problem. I would be highly thankful if you guide me that where is the problem. I can send UDF by email if needed.. Thanks in Advance, Regards, M. F. ALi |
