April 7, 2015, 09:46 |
patch option
ad
Rep Power: 12 |
hi guys
I have a little problem that hope someone could help me with,lets say we have 2 seperate tubes that are connected with a connector,i need to initialize each tubes with different pressure,the upper tube and the connector with 18 mpa and the bottom tube with 10 mpa,I used this approach,first i defined 3 zones for each tube,and initialized the whole system with 18 mpa,then i went to patch option and selected the bottom tube for the "zones to patch" and pressure for "variable" and 10mpa for "value",but when i tracked the pressure in the bottom tube the pressure was set to 18mpa instead of 10 mpa,I didnt use the mark and seperate options because of the complexibility of my geometry,can anyone help me please?thanks |
April 7, 2015, 18:46 |
Rep Power: 18 |
Are you sure you've applied the patch correctly (followed the steps in the user's guide)? It sounds like you've taken the correct steps, so it's strange the pressure is incorrect for the bottom tube.
Another way of achieving this pressure initialisation is to use the DEFINE_INIT macro (within a UDF) to create a set of initial values for your solution. |
April 14, 2015, 11:17 |
ad
Rep Power: 12 |
actually my approach was correct,monitoring the pressure was wrong,thanks anyway
April 26, 2017, 08:50 |
UDF Patch Coding
Karthik
Rep Power: 9 |
Hallo friends,
Currently i am working on Ansys fluent 17.2 for simulation of atmospheric plasma spraying. I need a help in performing a UDF coding for patches. For ex: i need to do 60 patches, ie one sec = 1 patch and so on 60 secs. I have to simulate the molten liquid particle coming form the spray gun and hits on the substrate, then it splashes and solidified. The size of my patch is x=0.25 and Y =0.25 and the size of the substrate (2D) is 0.05mm. Please help with this issue. |
Display Modes | |
Wind turbine simulation | Saturn | CFX | 58 | July 3, 2020 01:13 |
Waterwheel shaped turbine inside a pipe simulation problem | mshahed91 | CFX | 3 | January 10, 2015 11:19 |
Multiphase simulation of bubble rising | Niru | CFX | 5 | November 25, 2014 13:57 |
Low Mixing time Problem | Mavier | CFX | 5 | April 29, 2013 00:00 |
Error finding variable "THERMX" | sunilpatil | CFX | 8 | April 26, 2013 07:00 |
