udf for exothermic reaction:source term
hai
I am trying to write an energy source term UDF for an exothermic chemical reaction.the source term equation is q=contstant *(dx/dt),where dx/dt is the reaction rate of the equation Initially the value of x=0 and at the end the value of x=1 I wrote the UDF as follows(this I got from this site) DEFINE_INIT(my_init_fuc,d) { cell_t c; Thread*t; thread_loop_c(t,d) { begin_c_loop_all(c,t) { C_UDSI(c,t,0)= 0; } end_c_loop_all(c,t) } } /*UDF for solving Energy Equation HEAT SOURCE term */ DEFINE_SOURCE(heat_generation,c,t,ds,eqn) { real q_a; real physical_dt; physical_dt = RP_Get_Real("physical-time-step"); q_a=1000*(C_UDSI(c,t,0)-C_UDSI_M1(c,t,0))/physical_dt; ds[eqn]=0; C_UDMI(c,t,0)=q_a; /* Memory allocation for storing 'heat generation' */ return q_a; } Is this UDF right?? Can anyone please explain how this udf works exactly in fluent solver or how this calculation works in fluent especially these two lines C_UDSI(c,t,0)= 0; q_a=1000*(C_UDSI(c,t,0)-C_UDSI_M1(c,t,0))/physical_dt; ?? |
Hi mataus,
Did you get clear with the UDF? Because I am also facing the same problem and need help pls. Regards |
There is no source term for your heat. Hence there will no heat generation. While the source term you have given is just the transient term, which is the change in heat with respect to time. So, you first need to define the source for heat generation.
