"sg.h" header
Old   March 25, 2010, 13:36
Default "sg.h" header
MASOUD
MASOUD is on a distinguished road
When should we use "sg.h" header in the code??
MASOUD is offline   Reply With Quote
Old   June 24, 2013, 06:59
Default sg.h header
Prakash Ghose
pghoseju is on a distinguished road
I also want to know the same?
pghoseju is offline   Reply With Quote
Old   June 24, 2013, 08:35
Yash Ganatra
yashganatra is on a distinguished road
Its given in the UDF Manual. Mostly in Connectivity Macros section
yashganatra is offline   Reply With Quote
Old   June 27, 2017, 10:14
Nimmy
Nimmy Kovoor is on a distinguished road
Hi, Its a late reply...but somebody will be helped I hope.
If you want to access details of cells or faces like the inter-cell-centroid distances or the cell and face centroid distances or even the diffusive flux terms, you must include the sg.h header files since they are not available in the udf.h.
please find the link below to be clear:
http://www.afs.enea.it/project/neptu...udf/node99.htm
Nimmy Kovoor is offline   Reply With Quote
C runtime library internal header file Error gholamghar Fluent UDF and Scheme Programming 13 September 9, 2019 15:33
Output file with OpenFOAM header sega OpenFOAM Post-Processing 16 July 31, 2009 11:42
Missing math.h header Travis FLUENT 4 January 15, 2009 11:48
Compilation error with C++ header file Jack Martinez FLUENT 3 June 16, 2007 09:27
how to add header file shanu FLUENT 1 February 14, 2006 09:00
